[Fixed]Battlefield 2 will not boot.
3,352 (0.53/day)
Idaho
System Name Papa's Gamer / Gaming Backup / Asus ROG Gaming Laptop
Processor AMD Ryzen 7 5700X / Ryzen 5 3660/ Intel i7 4720HQ
Motherboard ASUS X570 / Asrock/ Asus G751JY
Cooling Wraith Stealth / Cheapo RGB / Factory
Memory Vengence DDR4 32 GB (3600) / G.SKILL Ripjaws DDR4 32 GB (3200) / 32 GB Micron PC-3 12800
Video Card(s) Sapphire Radeon RX 7700 XT 12 GB GDDR6 / Asus RX5700/ GTX 980 M
Storage Kingston 480gb SSD Hitachi Ultrastar 2 TB 1 TB WD SSD / 2 SSD 1 TB / 2 TB SSD
Display(s) Onn 49" Ultra wide 144 hz/ AOC 34-Inch Ultrawide Curved 75 hz and BenQ 27" 75 hz / 17" 1080 p
Audio Device(s) Realtek HD: 5.1 Technics DD / Sound Blaster Audigy / 5.1 Digital Home Theatre
Power Supply Thermaltake 750 watt / Corsair 550 watt Modular
Mouse Logitech G502 SE HERO / Logitech G602
Keyboard Gamesir GK100 / Steel Series / Cheap Magegee
Software Windows 11 Home 64-bit / Windows 11 Home 64-bit / Windows 10 Home 64-bit
BF2 won't on Vista 64 bit with new patch 1.5. It used to work fine,
but now it try to boot and screen just shuts down. No errors or
nothing.
Athlon2K15
HyperVtX™
7,909 (1.17/day)
O-H-I-O
Processor Intel Core i9 11900K
Motherboard MSI Z590 Carbon EK X
Cooling Custom Water
Memory Team DDR4 4000MHz
Video Card(s) ASUS TUF RTX 3080 OC
Storage WD WN850 1TB
Display(s) 43" LG NanoCell 4K 120Hz
Power Supply Asus Thor 1200w
Mouse Asus Strix Evolve
Keyboard Asus Strix Claymore
have you recently change anything besides installing the patch?
3,640 (0.59/day)
California
Switch to left hand or buy a new case.
Try to update your VGA driver?
3,352 (0.53/day)
Idaho
I changed everything. MB/Card/CPU. But this started before I did all that. Then I reloaded with all the upgrades and it still does it. Did it on one of my older XP machines too. Played fine one day and then it wouldn't work anymore.
3,352 (0.53/day)
Idaho
This is the older BF2 not BFBC 2 just so there is no mistake on which game.
921 (0.16/day)
SouthERN Africa
System Name inferKNIGHT
Processor Intel Core i5-4590
Motherboard MSI Z97i Gaming AC
Cooling Corsair H100i
Memory 2 x 4GB DDR3-1866 Crucial Ballistix Tactical Tracer (R/G)
Video Card(s) ASUS GTX 970 STRIX 3.5GB (+0.5GB? o.O)
Storage 1 x 256GB Cricial M550, 1 x 2TB Samsung 7200.12
Display(s) Samsung SyncMaster T260
Case Corsair Obsidian 250D
Power Supply Corsair RM750
Software Windows 8.1.1 pro x64
This happened to me with quite a few games; they worked fine, then suddenly started crashing at launch.
The only major system change I remember making before I noticed it was installing Catalyst 10.6.
I've tried several fixes, including rolling back to Catalyst 10.4, but all has failed so I've decided to just reinstall the OS.
Gonna stick with trusty Catalyst 10.4. The 10.5 and 10.6 are fails in my book.
100 (0.01/day)
System Name Hell PC
Processor Intel Core i7 4820k @ 4'50GHz
Motherboard Gigabyte GA-X79-UD3 BIOS F17
Cooling Noctua NH-D14
Memory 4x 4GB G.Skill Ripjaws DDR3 1333
Video Card(s) Asus GTX 770 Direct CU II @ 1306/3746
Storage OCZ Vertex 3 240GB SATA III, Seagate 1'5TB SATA II, Seagate 2TB SATA III
Display(s) Acer V243HAObd
Case Thermaltake Overseer RX-1
Audio Device(s) Onboard Realtek ALC898 HD 7.1
Power Supply Nox Pulsar Blue 750w
Software Windows 7 Home Premium SP1 x64
Benchmark Scores 3Dmark Ice Storm: 176205 3Dmark Cloud Gate: 25357 3Dmark Fire Strike: 7760
Battlefield 2 has some kind of issue like that for me, every time I reinstalled it under Vista 64. It was something related to the screen resolucion and refresh rate, it installs with a value that doesn't work in some cases until changed manually. Search for the file "x:\where you installed it\Battlefield 2\mods\bf2\Settings\Profiles\Default\video.con" and change with notepad the values to match your screen resolution. That worked for me.
Wrigleyvillain
PTFO or GTFO
7,702 (1.20/day)
Chicago
System Name DarkStar
Processor i5 3570K 4.4Ghz
Motherboard Asrock Z77 Extreme 3
Cooling Apogee HD White/XSPC Razer blocks
Memory 8GB Samsung Green 1600
Video Card(s) 2 x GTX 670 4GB
Storage 2 x 120GB Samsung 830
Display(s) 27" QNIX
Case Enthoo Pro
Power Supply Seasonic Platinum 760
Mouse Steelseries Sensei
Keyboard Ducky Pro MX Black
Software Windows 8.1 x64
IIRC it can be finicky under X64 do a Google search for help/tips...
3,352 (0.53/day)
Idaho
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
^ what he said
iirc, boise just changed monitors as well, which is a likely cause.
3,352 (0.53/day)
Idaho
Fawking loaded it on my XP machine and same damn thing. That pisses me off. I bought every damn expansion and have a bout a weeks time in over the years. Suckage. Come on Dice get it together.
3,352 (0.53/day)
Idaho
OK for any one reviewing this thread. I found out the problem. Once you load the original version of BF2 you have to load patch 1.41 before loading 1.5 or it will do what happened to me. I also am running it in Xp compatibility mode.
brandonwh64
19,542 (3.42/day)
yea thats in the changelog section of the 1.5 patch (1.41 REQUIRED)
3,352 (0.53/day)
Idaho
Yeah guess I should of read it : ) BF2 looks pretty sweet at
1920x1080 on the 27" for as old a game as it is.
brandonwh64
19,542 (3.42/day)
yea i have two BF2 keys here LOL one was from a friend that was gonna throw the game away but i gave it to me
3,352 (0.53/day)
Idaho
3,352 (0.53/day)
Idaho
Well if you decide you don't need it I'd take it and give it to my son. I just got his machine going. If not I'll just let him use mine. This is a Great old game. Until Call of Duty 4 I played this the most. Now I'm trying to catch up with that on BFBC2.
