- Jul 26, 2013
- 383 (0.10/day)
- Midlands, UK
System Name | Electra III |
Processor | AMD Ryzen 5 3600 @ 4.40 GHz (1.3 V) |
Motherboard | ASUS PRIME X570-PRO with BIOS 5003 |
Cooling | Cooler Master Hyper 212 EVO V1 |
Memory | 32 GiB Kingston FURY Renegade RGB (DDR4-3600 16-20-20-39) |
Video Card(s) | PowerColor Fighter RX 6700 XT with Adrenalin 24.2.1 |
Storage | 1 TiB Samsung 970 EVO Plus + 4 TB WD Red Pro |
Display(s) | Samsung U28R550Q + HP 22w |
Case | Fractal Design Focus G (Black) |
Audio Device(s) | Realtek HD Audio S1220A |
Power Supply | EVGA SuperNOVA G3 750 W |
Mouse | Logitech MX Master 2S |
Keyboard | MSI VIGOR GK71 SONIC Blue |
Software | Windows 10 21H2 Pro x64 |
Benchmark Scores | CPU-Z = 542/4,479 — R15 = 212/1,741 — R20 = 510/3,980 — PM 10 = 2,784/19,911 — GB 5 = 1,316/7,564 |
Hello all,
I shall be moving up to Ryzen some time in the fall. The system I currently use is a second-hand hand-me-down from a friend who originally bought it new from an eBay 'custom computer' seller. As such, the system itself is reasonable for what I use it for, but the case is absolute trash, and so I will be replacing it with either a Fractal Design Define R5 or R6.
I will be buying an Enermax Liqmax II 240 to cool the current CPU, and the Ryzen CPU. I'd really like a quiet system, hence going for the Define series in the first place, but in using a top-mounted radiator, with the newer Define R6, the ModuVent top cover is one large piece, while the ModuVent system in the older Define R5 comes as four separate fan covers.
I am just wondering how the AiO cooler would work with the Define R6. For the best cooling and noise balance, the Define R5 looks like it's the better choice, but perhaps I'm missing something with the Define R6. Ideally, I would like the newer case.
Are there any Define R5/R6 owners here who can shed some light on this dilemma?
Thank you!
Thank you!
