Fractal Design Expands Meshify C Line-Up
889 (0.32/day)
Fractal Design, leading designer and manufacturer of enthusiast PC cases and components, today announced two new additions to the popular Meshify C series high-airflow mid tower lineup. Meshify continues to strike an aggressive pose with its unparalleled cooling performance and defiant look, now available in a multitude of side panel variations. The introduction of the Meshify C with dual solid side panels and Meshify C - TG with lightly tinted tempered glass gives users all new choices, both functional and aesthetic. These new all-solid and light tint TG versions complement the original Meshify C - Dark TG with dark tint TG to satisfy a wide range of stylistic preferences.
An open ATX layout with intelligent space utilization creates an unrestricted airflow path from the mesh front intakes directly through key components to exhaust, ensuring heat is never an issue. The Meshify C series has a remarkably compact footprint with the high-end component support of a larger tower, and with seven fan mounts and multi-radiator liquid cooling capability, it has the cooling capacity to match. When performance is top priority and compromise is not an option, Meshify has you covered in style, now with three unique side panel configurations to choose from.
Key features
  • Streamlined high-airflow design
  • Performance and capacity of a larger tower in a remarkably compact mid-tower size
  • Newly designed angular mesh front panel maximizes air intake
  • Lightly tinted Tempered Glass side panel offers users a clean and clear view of their components (Meshify C TG version only)
  • Distinctive new styling with stealthy black-on-black aesthetic
  • Flexible storage options with room for up to 5 drives
  • Sturdy steel drive trays with vibration-dampening rubber grommets cushion hard drives for smooth, quiet and reliable operation
  • Two preinstalled Fractal Design Dynamic X2 GP-12 120 mm fans deliver optimum airflow with minimal noise
  • Open interior layout creates an unobstructed airflow path from front intake to rear exhaust
  • Easy-to-clean filters on the front, top and base with full PSU coverage and convenient front access
  • Full-length power supply shroud conceals drive cage and excess cabling for unrestricted airflow and a clean looking interior
  • Up to 35 mm of space behind motherboard plate with grommeted pass-through holes for clean cable routing
Specifications Meshify C & TG
MSRP
  • Meshify C - TG: USD89.99, GBP79.99, EURO89.99, SEK919
  • Meshify C: USD79.99, GBP74.99, EURO79.99, SEK849
Availability
Now
8,102 (1.32/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
506 (0.12/day)
Cyprus
Processor 13700KF - 5.7GHZ
Motherboard Z690 UNIFY-X
Cooling ARCTIC Liquid Freezer III 360 (NF-A12x25)
Memory 2x16 G.SKILL M-DIE (7200-34-44-44-28)
Video Card(s) XFX MERC 7900XT
Storage 1TB KINGSTON KC3000
Display(s) FI32Q
Case LIAN LI O11 DYNAMIC EVO
Audio Device(s) HD599
Power Supply RMX1000
Mouse PULSAR V2H
Keyboard KEYCHRON V3 (DUROCK T1 + MT3 GODSPEED R2)
Benchmark Scores Superposition 4k optimized - 20652
Just move the rear exhaust as intake, problem solved
crazyeyesreaper
Not a Moderator
9,841 (1.67/day)
System Name Old reliable
Processor Intel 8700K @ 4.8 GHz
Motherboard MSI Z370 Gaming Pro Carbon AC
Cooling Custom Water
Memory 32 GB Crucial Ballistix 3666 MHz
Video Card(s) MSI RTX 3080 10GB Suprim X
Storage 3x SSDs 2x HDDs
Display(s) ASUS VG27AQL1A x2 2560x1440 8bit IPS
Case Thermaltake Core P3 TG
Audio Device(s) Samson Meteor Mic / Generic 2.1 / KRK KNS 6400 headset
Power Supply Zalman EBT-1000
Mouse Mionix NAOS 7000
Keyboard Mionix
Do they really think this is good airflow? One intake fan for 3 exhaust fans plus a blower style GPU:
OR be smart reverse the fans at which point they are pulling air through the rad making dust removal easier while making the system positive pressure based. It also does two things, Pulling air through is just as effective as pushing it through. However due the fans being further in the case they airflow means added cooling for the VRM / GPU backplate while the front fan forces that air back toward the rear exhaust.
8,253 (1.17/day)
System Name money pit..
Power Supply EVGA 850 watt..
Mouse Logitech G700s
Keyboard Logitech K270
Software Win 10 pro..
all cpu heat is blown directly out of the case by the cpu cooler .. all gpu heat is blown directly out out the case by the gpu cooler .. it would work fine with no intake fans at all..
trog
855 (0.29/day)
Italy
Processor i7 2600K
Motherboard Asus P8Z68-V PRO/Gen 3
Cooling ZeroTherm FZ120
Memory G.Skill Ripjaws 4x4GB DDR3
Video Card(s) MSI GTX 1060 6G Gaming X
Storage Samsung 830 Pro 256GB + WD Caviar Blue 1TB
Display(s) Samsung PX2370 + Acer AL1717
Case Antec 1200 v1
Audio Device(s) aune x1s
Power Supply Enermax Modu87+ 800W
Mouse Logitech G403
Keyboard Qpad MK80
It comes with 2x12cm fans, you add another one in the front and one on top, here you have a good airflow.
Fx
1,332 (0.22/day)
Portland, OR
Processor Ryzen 2600x
Cooling Noctua
Video Card(s) EVGA 980ti FTW
Case Fractal Design Define R5
Mouse Mionix Castor
Keyboard Deck Hassium Pro
Bingo.
