- Jan 27, 2011
- 106 (0.02/day)
- Farmingdale, NY
Processor | Intel Pentium III Tualatin 1.4ghz (2x) |
Motherboard | SuperMicro P3TDDE |
Cooling | Antec Solution Plus CPU Cooler, replaced fan with 60mm LED fan (2x) |
Memory | Micron 1GB PC133 ECC Reg DDR Memory, 168-Pin SDRAM (4x) |
Video Card(s) | nVidia GeForce FX5500 PCI Video Graphics Card - 256MB |
Storage | 80gb |
Case | Ultra Products Wizard Mid-Tower ATX Case Black with Blue UV ULT31742 |
Audio Device(s) | Sound Blaster Live! X-GAMER |
Power Supply | 400 watt |
Software | Windows XP Pro |
I own a project that is about 70% complete with an old Antec Super Lan Boy case with an Asus Rampage formula that uses an LGA 775 CPU. The problem I faced is installing the front connectors to the motherboard that does NOT have the MIC port or AC'97 front panel to install into, instead I have an ADH.
An ADH connector in the motherboard shown below:
On my Supreme FX II card, I can most definitely install the AC'97 front panel connector into it, however, that leaves the MIC connector open and I need to know where I can install the MIC connector onto:
Below is the an old 5.1 channel Sound Blaster Live (1999) vintage. I am wondering if there is a way to connect the front panel MIC connector into this card since the Supreme FX II card (1x PCI-E slot) is next to the PCI card where I can install the Sound Blaster Live if I can successfully connect the MIC into it:
Anyways, here are the pictures, I could really use the help as I have not completed this project for over 7 years. Please let me know if connecting both the MIC and Sound front panel connectors can be installed into the ADH connector of the motherboard or using the 2 sound cards to act as a bridge for front panel sound and MIC. Thank you for your time and help
