System Name | Satan |
Processor | AMD 2700x with EK waterblock |
Motherboard | MSI X470 Gaming Pro |
Cooling | Custom open loop watercooled |
Memory | 16 GB Corsair Vengance RGB Pro @ 3466 Mhz |
Video Card(s) | Powercolor 5700 xt with EK full cover block |
Storage | Intel 660p 512 GB nvme Samsung 860 Evo 1 TB for storage SATA |
Display(s) | Viotek 32" curved 144 Hz 1440 P |
Case | Thermaltake Tower 900 |
Audio Device(s) | Realtek onboard |
Power Supply | Corsair Rmx 750 |
Mouse | Logitech G 602 wireless |
Keyboard | Corsair K68 |
Software | Windows 10 Pro |
OCZ Fatal1ty 750WWhat is the power supply and how old is it?
Processor | Ryzen 1600AF @4.2Ghz 1.35v |
Motherboard | MSI B450M PRO-A-MAX |
Cooling | Deepcool Gammaxx L120t |
Memory | 16GB Team Group Dark Pro Sammy-B-die 3400mhz 14.15.14.30-1.4v |
Video Card(s) | XFX RX 5600 XT THICC II PRO |
Storage | 240GB Brave eagle SSD/ 2TB Seagate Barracuda |
Display(s) | Dell SE2719HR |
Case | MSI Mag Vampiric 011C AMD Ryzen Edition |
Power Supply | EVGA 600W 80+ |
I agree, vram to be precise.The photo you posted looks like defective GPU.
System Name | Hellbox 5.1(same case new guts) |
Processor | Ryzen 7 5800X3D |
Motherboard | MSI X570S MAG Torpedo Max |
Cooling | TT Kandalf L.C.S.(Water/Air)EK Velocity CPU Block/Noctua EK Quantum DDC Pump/Res |
Memory | 2x16GB Gskill Trident Neo Z 3600 CL16 |
Video Card(s) | Powercolor Hellhound 7900XTX |
Storage | 970 Evo Plus 500GB 2xSamsung 850 Evo 500GB RAID 0 1TB WD Blue Corsair MP600 Core 2TB |
Display(s) | Alienware QD-OLED 34” 3440x1440 144hz 10Bit VESA HDR 400 |
Case | TT Kandalf L.C.S. |
Audio Device(s) | Soundblaster ZX/Logitech Z906 5.1 |
Power Supply | Seasonic TX~’850 Platinum |
Mouse | G502 Hero |
Keyboard | G19s |
VR HMD | Oculus Quest 3 |
Software | Win 11 Pro x64 |
I get this error 3 times in 2 weekDude !! I don't get it...there is NOTHING wrong with your temps at all. What are you trying to get out of all of this ??
this card already gived error 3 times fore test. As photo. veritical lines not good.Abusing it using Furmark could have easily damaged your VRAM. It puts a very high and unrealistic load on GFX cards and is generally not recommended for stress testing You may have damaged the card yourself using Furmark seeing as you’ve bought it new.
Mouse | G502 Hero |
Keyboard | G19s |
Well I assure you running Furnark on it won’t help. If it was doing it before then return it and next time use something likeI get this error 3 times in 2 week
There is the resultHe's just trying to reproduce that lockup to see if its still happens.
I recommend using Final Fantasy XV Benchmark on the highest settings. It uses a lot of VRAM and that's probably the problem.
I found PSU bill. Its 08/2013. Almost 7 year wowWhat is the power supply and how old is it?
