G.Skill Aegis?
252 (0.08/day)
Norway
System Name none
Processor AMD R9 9950X
Motherboard GIGABYTE B650E AORUS MASTER
Cooling ARCTIC Liquid Freezer III 420
Memory 32GB G.SKILL @6400MT/s CL32-36-36-28-68 tweaked sub-timings
Video Card(s) ASUS TUF 4090
Storage Samsung PM9A1
Display(s) SAMSUNG 32" IDK WHAT
Case Corsair 7000D
Audio Device(s) none
Power Supply Corsair HX1500
Mouse Corsair
Keyboard Corsair K95 Platinum
Benchmark Scores Check out my YT channel, Technology Hive: https://www.youtube.com/channel/UCeHYX8NGoRj-kZiumUhUsJw
Anyone know if this RAM is as good as this guy says? I'm looking for cheap ram for my new build but idk how to tell whats good...
Toothless
Tech, Games, and TPU!
9,815 (2.42/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Aegis is as general as it gets from G.Skill. You plug it in and it works.
14,545 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
I think from memory, it was designed with AMD systems in mind, but will work fine with Intel also.
252 (0.08/day)
Norway
System Name none
Case Corsair 7000D
Mouse Corsair
There are two variants. The 3200Mhz one and the 3000Mhz kit. I hope they're the same IC's.
1,980 (0.39/day)
Mainland Britain
System Name H2o Box
Processor Intel(R) Xeon e5-2690 v2 Stock 3.300 GHz stock
Motherboard MSI X79A-G43 Plus (MS-7760) v3
Cooling CPU EK & Phobya G-Changer 360 V2.0 RAD H2o VGA "AlphaCool M18" Hybrid [pump replaced 18/8/21]
Memory G.Skill TridentX 16Gb 11-12-12-32 2T @ 1866Mhz [locked]
Video Card(s) Zotac GTX 1080ti AMP EXTREME
Storage HyperX Fury 120GB & Savage 480GB SSD, Seagate 250GB,250GB 7200rpm Kingston 64GB SSD
Display(s) Asus TUF Gaming VG32VQR 2560*1440 165Hz VA Panel
Case Corsair O-800D
Power Supply Be Quiet! [Dark Power Pro 11] 1200W CM replaced [7-4-2017]
Mouse Zelotes T-90
Keyboard K66 Mechanical US Layout
Software Win 10 Pro 64Bit v 20H2 / OS [build 19043.1237] WFEP 120.2212.3530.0
Select motherboard
look at memory compatibility chart
make informed decision based on supported timings and product availability
14,545 (3.79/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
You haven't mentioned which team you are going for.
AMD likes fast Ram, and even Cas latencies, Intel's not that fussy.
Edit: I assume you want B die?
252 (0.08/day)
Norway
System Name none
Case Corsair 7000D
Mouse Corsair
I have it now stable at 3600Mhz 16-19-19-19-39 TRC 58 TRFC 400 @1.35v I would post the video of how I did it but I think I will be banned LOL I just followed a video I saw.
Sorry. I'm running a separate rig as my back up. It's an AMD 3600. Good memory controller. Can do 1900 FCLK. It also clocks to 4.5Ghz 1.35v. So I'd like something like B-Die. But I've gotten to play with this D-Die kit from G.Skill Aegis. Got it from 3000mhz to 3600mhz 16-19-19-19-39 58TRC and 400 TRFC at 1.35v so I'm pretty happy for the price. Around $65.00 for 16GB.
