G.Skill Trident Lighting Control High CPU usage
1,614 (0.23/day)
The Gulag Casino
System Name ROG 9800X3d By purecain
Processor AMD Ryzen 7 9800X3D
Motherboard ASUS Crosshair X670E Hero
Cooling Noctua NH U12A
Memory 64Gb G.Skill Trident Z5 neo RGB 6400@6000mhz@1.41v
Video Card(s) Aorus RTX4090 Extreme Waterforce
Storage 990Pro2Tb-1TbSamsung Evo M.2/ 2TbSamsung QVO/ 1TbSamsung Evo780/ 120gbKingston Now
Display(s) LG 65UN85006LA 65" Smart 4K Ultra HD HDR LED TV
Case Thermaltake CoreX71 Limited Edition Etched Tempered Glass Door
Audio Device(s) On board/NIcomplete audio 6
Power Supply Seasonic FOCUS 1000w 80+
Mouse M65 RGB Elite
Keyboard K95 RGB Platinum
Software Windows11pro
Benchmark Scores [url=https://valid.x86.fr/gtle1y][img]https://valid.x86.fr/cache/banner/gtle1y-6.png[/img][/url]
Just a heads up
I noticed my 5950x was at 74c at start-up. After stopping this process my temps dropped to 50c.
I recommend anyone else using this stops the process after the memory RGB has been set by the program.
Stopping the process doesnt seem to effect the RGB colour mode chosen.:toast:
same problem
its annoying how i need to close the software on every boot
(AMD Ryzen 9 5950x
32Gb G.Skill Trident royal RGB)
Pretty sure, if you look, the G.Skill app for RGB has had issues for a while now.
As said in the OP, once changed, it is set to the memory until changed. The app only needs to be used long enough to set the color, or when possible, use whatever sync suite the motherboard offers instead. I know, I know, the G.Skill app has more color options.
In my use, I installed it, changed the colors, then uninstalled it after. Sort of a PITA, but I dont tinker with the RGB much.
i will do it just like that thanks
