G733ZW 12900H + 3070 Ti High CPU Temps and Low CPU Package Power
bogarogstrix
5 (0.00/day)
Hello everyone, I would like your help for this problem that caught my attention on the G733ZW model computer that I just bought.
While the system is idle, the CPU suddenly reaches 90-95 degrees and drops back to 40-45 degrees. In Turbo Mode, Cpu Package Power sees maximum 110-115W values, when I research other users with the same computer can see 125-130W values. In simple games, the temperature values are 80-85 degrees on average and can suddenly reach 95 degrees in the game.
ir_cow
5,013 (0.82/day)
USA
Doesn't seem like major problem. The fan profile isn't ramping up until it gets hot.
bogarogstrix
5 (0.00/day)
Is it normal for the temperature to constantly change between 60-80 degrees and suddenly rise to 90 degrees and go down again while playing League of Legends?
ir_cow
5,013 (0.82/day)
USA
Yes. quick spikes in clock frequency will do that. The temps go down once the fan kicks in. This is very common for laptops in my opinion. I'm sure having a silent fan profile doesn't help either.
bogarogstrix
5 (0.00/day)
I don't have any problems with fan noise. only the sudden rise of these temperature values made me suspicious. One last question, while performing a CPU stress test, the CPU Package temperature value is fixed at 94-95 degrees. As soon as I finish the test, it drops to 40-45 degrees again. Plugged in and in Turbo mode, is this normal too?
9,800 (3.23/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
It's an 100W CPU in a laptop, it's going to jump to 90C+ all the time.
30,505 (7.07/day)
Yes. LoL is a CPU-centric game and that kind of system behavior is normal.
To improve thermals and reduce the temp spikes, increase your fan curve in your BIOS settings. In most situations, you can set your fans to a minimum of 40% without increasing noise, depending on the fans and how much noise you feel is acceptable. For example I have my fans set to a minimum of 50% and have them set to 80% at 70c and 100% at 80c. Because of that curve I rarely see my CPU go above 65c. The noise my system outputs is audible, but not annoying. I would rather my system be cool and make some noise I can live with than run hot.
bogarogstrix
5 (0.00/day)
I agree with what you said yes. I don't care about the fan noise. but I couldn't find the fan section in the bios settings…
30,505 (7.07/day)
Oh wow. The ASUS Strix laptops should have fan profiles that you can set the curve for in the UEFI BIOS. They should be in there somewhere in the advanced settings.
4,925 (0.79/day)
Multidimensional
System Name Intel NUC 12 Extreme
Processor Intel Core i7 12700 (E Cores Disabled)
Motherboard Intel NUC Module Motherboard
Cooling NUC Blower Cooler + 3 x 92mm Fans
Memory 64GB Corsair 3200Mhz CL22
Video Card(s) PowerColor RX 9070 16GB Reaper
Storage Silicon 512GB Gen4 SSD + 256GB SD Card
Display(s) Sony 4K Bravia X85J 43Inch TV 120Hz
Case Intel NUC 12 Extreme Mini ITX Case
Audio Device(s) Realtek Audio + Dolby Atmos
Power Supply SFX FSP 650 Gold Rated PSU
Mouse Logitech G203 Lightsync Mouse
Keyboard Red Dragon K552W RGB White KB.
VR HMD ( ◔ ʖ̯ ◔ )
Software Windows 10 Home 64bit
Benchmark Scores None. I also own a Apple Macbook Air M2
Download Asus Armoury Crate, should be some fan curve settings in there.
bogarogstrix
5 (0.00/day)
yes i looked but i couldn’t see such a setting section
Yes i know the settings on the armoury crate
9,800 (3.23/day)
Case Phanteks NV7
I doubt these kinds of laptops allow for full control over fan speeds as a safety precaution.
631 (0.54/day)
Processor AMD Ryzen 7 5800X3D
Cooling Custom Watercooling
Display(s) Samsung G7 27" x2
Mouse Logitech G903
Keyboard Steelseries Apex Pro
Long way from some control to full control. They could have a couple profiles to choose from or let you adjust the curve upwards manually, without compromising safety.
9,800 (3.23/day)
Case Phanteks NV7
If true, which I doubt, it's a stupid safety precaution.
Imagine if you could set the fans to 0%, in a laptop with 100W+ CPU and GPU, sounds like a pretty stupid thing to allow.
I imagine that you can set some custom fan curves but they're probably very constrained and will get overridden if the temps are too high.
175 (0.15/day)
System Name Custom Watercooled
Processor 10900k 5.1GHz SSE 5.0GHz AVX
Motherboard Asus Maximus XIII hero z590
Cooling XSPC Raystorm Pro, XSPC D5 Vario, EK Water Blocks EK-CoolStream XE 360 (Triple Fan) Radiator
Memory Team Group 8Pack RIPPED Edition TDPPD416G3600HC14CDC01 @ DDR4-4000 CL15 Dual Rank 4x8GB (32GB)
Video Card(s) KFA2 GeForce RTX 3080 Ti SG 1-Click OC 12GB LHR GDDR6X PCI-Express Graphics Card
Storage WD Blue SN550 1TB NVME M.2 2280 PCIe Gen3 Solid State Drive (WDS100T2B0C)
Display(s) LG 3D TV 32LW450U-ZB and Samsung U28D590
Case Full Tower Case
Audio Device(s) ROG SupremeFX 7.1 Surround Sound High Definition Audio CODEC ALC4082, ESS SABRE9018Q2C DAC/AMP
Power Supply Corsair AX1000 Titanium 80 Plus Titanium Power Supply
Mouse Logitech G502SE
Keyboard Logitech Y-BP62a
Benchmark Scores https://valid.x86.fr/2rdbdl https://www.3dmark.com/spy/27927340 https://ibb.co/YjQFw5t
All the laptops I have worked on have bad cooling. One with an AMD cpu hits 96c just because of Windows defender and then idles at 60c. This is when it boosts fully in Windows 10 when connected to the mains. Really procrastinating over changing the thermal paste.
244 (0.13/day)
I bought the same laptop and its temp behavior totally stunned me. It jumps from 45 to 96 in milliseconds and then goes back down just as fast. It happens all the time and the Limit box in ThrottleStop is like a discotheque. Sometimes PROCHOT lights up (95 C), but the highest temp recorded is 85. Never seen something like this. The PROCHOT under the table shines most of the time just as THERMAL in Limit box on Core and Ring. The fan curve is set to hit 100% at 60 C but guess what - it happens with a huge delay, long after the spike series calm down for a while. Is this really a normal behavior? Is yours still working the same way?
PS: What is even more strange, the laptop makes 18 000 points in CB23, while the average result for this CPU is around 16 500.
