Gap between heatsink & GPU
5,202 (0.89/day)
System Name Dust Collector
Processor AMD Ryzen 5 3600X
Motherboard Asus B550I Aorus Pro WiFi AX
Cooling Alpenfohn Black Ridge V2 w/ Noctua NF-A9x14
Memory Corsair Vengeance LPX 16GB DDR4 3200MHz/CL16
Video Card(s) Power Color Red Dragon RX 5700 XT
Storage Samsung EVO+ 500GB NVMe
Display(s) Dell S2721DGF
Case Dan Case A4
Power Supply Corsair SF600 Platinum
Mouse Logitech G603
Keyboard Logitech G613
For the past few months I've been using a copper shim between the GPU and heatsink of my laptop because there's a rather large (1mm~) gap between the two. The thing is getting rather hot, to the point where my hand would start numbing after touching the bottom for too long. I can't remember how the laptop was like prior to me taking it apart (for fun) to replace the TIM with MX-2. The laptop originally had a thermal pad between the GPU and heatsink, but that obviously ripped when I dismantled the laptop.
I assume the gap is far too wide to simply fill up with TIM, but I'm sure there's a better solution than a flat copper shim because the heatsink base & GPU are not parallel, there's a slight slant, so I'm not sure how the contact is. It's also transferring heat between three layers (two layers of TIM and the copper), which has got to be hindering cooling.
I've been trying to find high-quality thermal pads, but I can't seem to find any on popular tech shops. Maybe I'm just looking for the wrong thing (are they even thermal pads?) or they're just impossible to find.
SOLUTIONS PLEASE!
2,706 (0.41/day)
Oulu, Finland
System Name Enslaver :)
Processor Ryzen 7 7800X3D
Motherboard ASUS TUF Gaming B650-Plus
Cooling CPU: Noctua D15 G2, Case: 2 front in, 1 rear out
Memory 2x16GB Kingston Fury Beast RGB 6000MHz
Video Card(s) ASUS TUF RTX 4070Ti OC
Storage Samsung Evo Plus 1TB NVMe , internal WD Red 4TB for storage, WD Book 8TB
Display(s) LG CX OLED 65"
Case Lian Li LANCOOL II Mesh C Performance
Audio Device(s) HDMI audio powering Dolby Digital audio on 5.1 Z960 speaker system
Mouse Logitech G700
Keyboard ASUS Strix Tactic Pro
Software Windows 11 Pro x64
One guy at TPU has a ongoing sales thread for thermal tape - i dont remember more...
970 (0.17/day)
Granby, Qc. Canada
System Name Loose nuts & bolts
Processor FX-8350 - EK Supreme HF full nickel
Motherboard ASUS Sabertooth 990FX R2.0
Cooling Water EK goodness all around 2xBlack Ice X-280
Memory 2 x8G HyperX Fury 1600 @ 9-9-9-24-1T
Video Card(s) 2 x XFX RX 480 w/EK-FC RX 480 nickel+Acetal
Storage Samsung 850 Evo + 2xWD Black 500GB in RAID0
Display(s) Crossover 27" 2560x1440 110Hz OC
Case Cooler Master HAF XB EVO
Audio Device(s) on board
Power Supply Corsair HX850
Software Win 10 Enterprise x64
Thermal tape is too thin, what Kantastic needs is a thermal pad similar to what EK sells.
I'm sure you can find the same or similar around your neck of the woods Kant
5,202 (0.89/day)
Case Dan Case A4
Mouse Logitech G603
Definitely not thick enough, the gap is at least 1mm.
There ya go! Thanks so much! I'm going to give these a shot, I found them in the USA. THANKS AGAIN!
2,706 (0.41/day)
Oulu, Finland
Mouse Logitech G700
5,202 (0.89/day)
Case Dan Case A4
Mouse Logitech G603
I guess its not possible to stack them and make a sandwich?
I don't know about thermodynamics, but between the finger oils and dust between all the layers, I doubt the performance will be better than my copper shim.
970 (0.17/day)
Granby, Qc. Canada
It's what I use for my GPU blocks. Glad I could help :toast:
3,565 (0.64/day)
By the Channel Tunnel, Kent, England
System Name Benny
Processor Phenom II 1055t @ 3.3GHz; 300x11; 1.380v; NB 2700; HT 2400
Motherboard ASUS Crosshair IV Formula (2002 BIOS)
Cooling Thermalright TRUE 120 Black + 2 Xilence Red Wing PWM 120mm (push/pull) + polycarbonate fan holders
Memory 8GB GeIL Ultra 2133MHZ C9 running at 1600MHz @ 7-7-7-21 1T 1.5v
Video Card(s) MSI Twin Frozr II GTX470 @ Stock w/CPU fan cable-tied on, as one of the GPU fans broke.
Storage 60GB OCZ Agility3 (OS);500GB WDC Grn; 1x1TB WDC Blk (Backup)
Display(s) ASUS PA823Q
Case Silverstone Raven 2 (all cables custom sleeved with velcro mod on side panel...)
Audio Device(s) X-Fi (Onboard) + Harmon Kardon HK6100 amp powering JVC HA-RX700's with Zalman mic
Power Supply Corsair HX650W
Software Win7 Pro x64
Benchmark Scores No benchies so making this space useful! Corsair M90, Logitech G19. Phobya FlexLight LED's (gawjus)
The copper shim may be too thin.
I can help with sourcing these copper shims if you need a thicker one.
A copper shim should perform much better than a thermal pad IMO.
AsRock
TPU addict
19,255 (2.95/day)
UK\USA
Cooling D15
Any chance of some pictures as it's kinda crazy thinking that the manufacture left a 1mm gap but you never know huh.
maybe it's just not lining u right with some thing ?. And copper is going be way better if you can get 2 of the right thickness.
Edit: maybe some things to tight or just not lined up right.
3,565 (0.64/day)
System Name Benny
I should have given you a proper link, sorry.
Here's a shop on the bay that sells copper shims specifically for certain laptops. Another member on here wanted one, he had to measure his old thermal pad to get the right thickness (as they didn't have details on his laptop).
You can measure the gap by placing some blu-tac on the GPU (with a small piece of paper between the blu-tac and HS to stop it sticking to the HS) and fitting the laptop back together, then taking it apart again.
Then cut away the excess blu-tac from around the the GPU and measure it. For the easily scared, don't worry Blu-tac is surprisingly easy to remove from motherboards.
It sounds strange, but after having a long hard think of how to measure that gap without a feeler gauge etc., it's all I could come up with :eek:
58 (0.01/day)
A copper shim properly sized should work very well. It seems unlikely that there was that significant of a gap from the factory. Is is possible something was re-assembled improperly? There should be no gap for paste TIM and only a few thousandths of an inch for a pad unless it is an unusually thick pad. 1mm seems way too big of a gap.
3,016 (0.51/day)
vermont
System Name The wifes worst enemy
Processor i5-9600k
Motherboard Asrock z390 phantom gaming 4
Cooling water
Memory 16gb G.skill ripjaw DDR4 2400 4X4GB 15-15-15-35-2T
Video Card(s) Asrock 5600xt phantom gaming 6gb 14gb/s
Storage crucial M500 120GB SSD, Pny 256GB SSD, seagate 750GB, seagate 2TB HDD, WD blue 1TB 2.5" HDD
Display(s) 27 inch samsung @ 1080p but capable of much more ;)
Case Corsair AIR 540 Cube Mid tower
Power Supply EVGA GQ1000W MODULAR
Mouse generic for now
Keyboard generic for now
Software gotta love steam, origin etc etc
Benchmark Scores http://hwbot.org/user/philbrown_23/
no matter a thermal pad or not if you have a gap its gonna have shitty heat transfer, my suggestion is working on a preassure mod of some sort to makre your gap go bye bye. copper shims are the best for gaps thermal pads will not do anything but make it worse. think of it like this. vrms use thermal pads but when all vrms arent getting proper contact they over heat, and compared to a cpu vrms dont get nearly as hot as fast. what do we do when our vrms arent getting contact?? add a backplate or some washers on the screws. thats my suggestion. maybe take pics if im getting you wrong.
5,202 (0.89/day)
Case Dan Case A4
Mouse Logitech G603
I checked my eBay purchase and it turns out the shim I bought was .56mm thick, I thought it was .75mm thick. The gap is roughly 1mm, I would say anywhere from .75-1mm, I'm going to double check again when I have the chance.
That's just how HP/Compaq laptops are, the main market for copper shims is HP laptop owners. Apparently large gaps & poor conducting thermal pads is a notorious issue.
I'm almost positive there was no issue with reassembly since I did it like 4 times.
I was afraid thermal pads wouldn't work as well as TIM and a piece of copper.
I honestly don't know why there's such a large gap between the heatsink and GPU. Any sort of mod is out of the option because the GPU & CPU heatsink is one piece connected via a copper heatpipe. The heatsink for my particular laptop (Compaq CQ60-220US) also has no screws for the GPU block, it relies solely on the pressure from the 4 screws on the CPU block. Not only is a pressure mod out of the question, even if it were possible I'd probably ruin the contact on the CPU end or even worse, break something.
The only thicknesses I can find on eBay are .56mm, .66mm, .8mm, 1mm, 1.2mm, and 1.5mm. I don't want to wait 2 weeks for the shim to come from Asia, so the only options left from US sellers are .56mm, .66mm, and 1mm. I just ordered a 1mm piece, hopefully a thicker piece will make tighter contact and result in better heat conduction.
I'm also giving the EK thermal pad a shot too. Next step is to figure out how to monitor my CPU/GPU temperatures to see which is the better option.
4,012 (0.70/day)
Sarasota, Florida, USA
System Name Awesomesauce 4.3 | Laptop (MSI GE72VR 6RF Apache Pro-023)
Processor Intel Core i7-5820K 4.16GHz 1.28v/3GHz 1.05v uncore | Intel Core i7-6700HQ @ 3.1GHz
Motherboard Gigabyte GA-X99-UD5 WiFi LGA2011-v3| Stock
Cooling Corsair H100i v2 w/ 2x EK Vardar F4-120ER + various 120/140mm case fans | Stock
Memory G.Skill RJ-4 16GB DDR4-2666 CL15 quad channel | 12GB DDR4-2133
Video Card(s) EVGA GTX 1080 Ti Hybrid SC2 11GB @ 2012/5151 boost | NVIDIA GTX 1060 6GB +200/+500 + Intel 530
Storage Samsung 840 EVO 500GB + Seagate 3TB 7200RPM + others | Kingston 256GB M.2 SATA + 1TB 7200RPM
Display(s) Acer G257HU 1440p 60Hz AH-IPS 4ms | 17.3" 1920*1080 60Hz wide angle TN notebook panel
Case Fractal Design Define XL R2 | MSI
Audio Device(s) Creative Sound Blaster Z | Realtek with quad stereo speakers and subwoofer
Power Supply Corsair HX850i Platinum | 19.5v 180w Delta brick
Software Windows 10 Pro x64 | Windows 10 Home x64
Have you tried HWMonitor from the people that make CPU-Z? Works good with both my new and old laptops (although there doesn't seem to be a temperature sensor in my RS880M to read, but my CPU, NB and GPU are all on the same heatpipe so it doesn't matter too much).
5,202 (0.89/day)
Case Dan Case A4
Mouse Logitech G603
I see two temperatures (TZS0 & TZS1) but the CPU cores are stuck at 84/83. I'm not sure what the TZS values are, but they're fluctuating a bit.
4,012 (0.70/day)
Interesting. Well, good luck with your mod. I had an old HP DV6000 back in the day that had one of those stupid thermal pads, but it was just a crappy Turion 64 X2 TL-50 and GeForce 6150 IGP so I didn't care about it. There might be one on my northbridge (I can't remember), but again the HD 4250 runs cool enough, and my 5650 + CPU have direct contact on the same heatpipe and maintain temperatures of 70c or less under load, so all is good. :toast:
AsRock
TPU addict
19,255 (2.95/day)
UK\USA
Cooling D15
Think your on to some thing there, maybe soft rubber washers to get it some what flat with a copper plate maybe.
Eww thank god i did not pick one of those up lol. I guess i can be happier mines a DELL and uses screws.
3,016 (0.51/day)
vermont
Processor i5-9600k
Cooling water
can you bend the heatpipe just a bit?? I had to fix a laptop that way, no screws on the gpu and it was so bad it wouldnt boot windows before shutting down. used needle nosed pliers and some patience to get it right but you can bend the heatpipe to force more gpu preassure
5,202 (0.89/day)
Case Dan Case A4
Mouse Logitech G603
The heatpipe is soldered onto a solid piece of metal, no clue what type but I tried bending it and it wouldn't budge. I'm thinking a shim is my only option so far.
Would anyone happen to excel at thermodynamics and know whether or not a large shim would work better than a smaller shim with the same thickness?
