Geforce 8600GT
3,051 (0.60/day)
System Name The SwagMachine / The Sister
Processor Core i5 3570K @5.2ghz 1.3V/ 1100T
Motherboard ASUS P8Z77-V / ASUS M5A99X EVO
Cooling Phanteks PH TC14PE / Corsair H40
Memory M379B5273DH0-YK0 2X4GB + PVI316G213C1QK 2X4GB / 2x4GB Patriot 2133
Video Card(s) PNY 780Ti /Windforce 7950
Storage 2xSamsung 840 EVO 250gb+WD10EZEX + WD30EZRX/ 1x WD1500 Black
Display(s) AOC Q2963PM+Acer S200HL / Acer S200L+ LG 22LD350
Case Fractal Define R4 / NZXT Trinity
Audio Device(s) Asus Xonar DG / Asus Xonar DG
Power Supply Seasonic 750X / ROSEWILL RG630-S12 630W R
Mouse Razer Deathadder Chroma / Roccat Kone+
Keyboard Razer Blackwidow 2013 Stealth / Roccat Isku
Software Windows 8.1 Pro / Windows 7 Ultimate
Benchmark Scores one time I scored a 3 on 3dmark 11
I made my mom a rig a while back with old spare parts (athlon 64 x2 5200 or something, 4 gigs 667, 450 watt OEM psu, Hp case, some old asus board) and I put a Geforce 8600GT in there, I don't remeber it being as hot as it is, I checked the temps and doing normal tasks she is getting about 85C. It used to only go that high when I was gaming. (side note one time it went to 110C!)
1,311 (0.23/day)
The Netherlands
System Name PC ||Zephyrus G14 2023
Processor Ryzen 9 5900x || R9 7940HS
Motherboard MAG B550M MORTAR WIFI ||
Cooling 1x Corsair XR5 360mm Rad||
Memory 2x16GB HyperX 3600 @ 3800 || 2x16GB DDR5 @ 4800MTs
Video Card(s) MSI RTX 2080Ti Sea Hawk EK X || RTX 4060
Storage Samsung 9801TB x2 + Striped Tiered Storage Space (2x 128Gb SSD + 2x 1TB HDD) || 1TB NVME
Display(s) Iiyama PL2770QS + Samsung U28E590, || 14' 2560x1600 165Hz IPS
Case SilverStone Alta G1M ||
Power Supply Cooler Master V850 SFX || 240W
Mouse ROG Pugio II
Software Win 11 64bit || Win 11 64bit
Then i guess your cooling efficiency went way down, or the power usage went way up!
Try looking for a clogged cooler, or background programs that make the graphics card ramp up(browsers with flash for an instance)
3,051 (0.60/day)
I even put my HDD in, just on facebook it's about 70C
1,311 (0.23/day)
The Netherlands
Mouse ROG Pugio II
then i guess you should look at the cooler, specifically, whether its still seated correctly and if theres any dust in there.
Another option is checking wether the cooler can suck in enough air, and wether it has enough room to vent it. (For an instance, if the pc is with the back against the wall, it cannot sufficiently blow away all the hot air, leading to insufficient cooling and a hot graphics card)
2,365 (0.44/day)
Marlow, ENGLAND
System Name Chachamaru-IV | Retro Battlestation
Processor AMD Ryzen 9 5900X | Intel Pentium II 450MHz
Motherboard ASUS ROG STRIX X570-F Gaming | MSI MS-6116 (Intel 440BX chipset)
Cooling Noctua NH-D15 SE-AM4
Memory 32GB Corsair DDR4-3000 (16-20-20-38) | 512MB PC133 SDRAM
Video Card(s) nVIDIA GeForce RTX 4070 FE | 3dfx Voodoo3 3000
Storage 1TB WD_Black SN850 SSD (OS), 3TB Toshiba (Storage), 8TB Seagate FireCuda/2TB WD_Black SN580X (Steam)
Display(s) Samsung Odyssey G5 27" @ 1440p144 & Dell U2412M @ 1200p60
Case SilverStone Seta A1 | Beige box
Audio Device(s) Creative Sound Blaster AE-7, Edifier speakers, Grado Labs SR80 X headphones | Sound Blaster AWE64
Power Supply EVGA Supernova 750 G2 | 250W ASETEC
Mouse MX Master 3S| Microsoft Serial Mouse v2.0A
Keyboard Vortex Race3 | Dell AT102W
Software Microsoft Windows 11 Pro | Microsoft Windows 98SE
Or it could be borked. 110 degrees for a GPU is not good.
3,352 (0.60/day)
System Name Dark Stealth
Processor Ryzen 5 5600x
Motherboard Gigabyte B450M Gaming rev 1.0
Cooling Snowman, arctic p12 x2 fans
Memory 16x2 DDR4 Corsair Dominator Pro
Video Card(s) 3080 10gb
Storage 2TB NVME PCIE 4.0 Crucial P3 Plus, 1TB Crucial MX500 SSD, 4TB WD RED HDD
Display(s) HP Omen 34c (34" monitor 3440x1440 165Hz VA panel)
Case Zalman S2
Power Supply Corsair 750TX
Mouse Logitech pro superlight, mx mouse s3, Razer Basiliskx with battery
Keyboard Custom mechanical keyboard tm680
Benchmark Scores 70-80 fps 3440x1440 on cyberpunk 2077 max settings
What kind of 8600 is it?
3,051 (0.60/day)
GT 512 mbs. And it was at 110C when it was newish, I was playing L4D with it on max for about 2 hours.
3,352 (0.60/day)
Case Zalman S2
I mean Asus, palit, evga?
1,311 (0.23/day)
The Netherlands
Mouse ROG Pugio II
This probablly means that you had a bad card from the start, either because of faulty hardware or an incorrectly seated cooler.
Tatty_Two
Gone Fishing
26,029 (3.70/day)
Worcestershire, UK
Software Win 11 Home x64
8600GT + Auto fan control = Fail......... I had one and it ran hot, I needed to crank the fan upto 60% just to get acceptable temps.
brandonwh64
19,542 (3.42/day)
Re do the TIM on the card and change the fan profile.
348 (0.07/day)
Portugal
Processor Intel i7 7700k @4.5Ghz
Motherboard Asus Strix Z270E Gaming
Cooling Cooler Master Nepton 120XL
Memory Corsair Vengeance LED Red 2x8GB 3000Mhz
Video Card(s) Asus Strix GTX980TI
Storage Samsung SSD 840 EVO 250GB
Display(s) BenQ XL2411Z / Dell SE198WFP
Case NOX Hummer TG RGB
Power Supply Corsair RM850
Mouse Razer Mamba Chroma
Keyboard Razer Blackwidow Chroma
Software Windows 10 - 64bit
Could it be the silent version ? It has no fan so its normal to hit those temps, i had one some time ago.
Tatty_Two
Gone Fishing
26,029 (3.70/day)
Worcestershire, UK
Good point, if it is the passive with just the heatsink he needs to mount a 80 or 90mm fan on it!
CDdude55
Crazy 4 TPU!!!
8,178 (1.26/day)
Virginia
System Name CDdude's Rig!
Processor AMD Athlon II X4 620
Motherboard Gigabyte GA-990FXA-UD3
Cooling Corsair H70
Memory 8GB Corsair Vengence @1600mhz
Video Card(s) XFX HD 6970 2GB
Storage OCZ Agility 3 60GB SSD/WD Velociraptor 300GB
Display(s) ASUS VH232H 23" 1920x1080
Case Cooler Master CM690 (w/ side window)
Audio Device(s) Onboard (It sounds fine)
Power Supply Corsair 850TX
Software Windows 7 Home Premium 64bit SP1
I actually still own an 8600 GTS(don't use it anymore though) and it naturally ran hot, at idle it generally hovered around 67c and it really started to heat up at load.
The cooler is insufficient imo, that small heatsink and fan doesn't do much of a good job keeping the temps down. But keep in mind, it wasn't meant as really a gaming orientated GPU so that could explain the lack of a better heatsink.
3,051 (0.60/day)
Yeah, theres a small fan and I usually had it maxed. I tried to take off the cooler, but I don't have a screw driver small enough atm. I'm gunna go to my dad's tomorrow and get one.
9,923 (1.80/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
yeah try to replace thermal paste reseat the hsf and using a fan, 80mm fan is pretty cheap and it performs pretty good on that (i use if for my old 8600) and improve your case airflow
3,051 (0.60/day)
This isn't in my rig, it's in the computer I made for my mother. It is a HP case with only mounting for a 92mm fan. She says it is too loud normally pluged in so I have it undervolted. I finally got the cooler off and I cleaned all the thermal paste and just put some coolermaster thermal paste that came with my cooler. I'm testing it right now.
9,923 (1.80/day)
Jakarta, Indonesia
Case Icute Super 18
i guess with new thermal paste an reseat right. it should be ok
3,051 (0.60/day)
Idling temps are now at 52C (old used to be 60) under load it is at 90C(used to be about 96 running 3Dmarkvantage)
5,480 (0.88/day)
Australia
Still seems a little high to be honest. I have two here in SLi (256MB versions) and they idle in the 40's and at laod they will hit in the 70c maxed out, and the case hasn't got great cooling ether.
! of my cards did what yours did and started to run very hot, and yes it was the Thermal paste that needed replacing, this fixed my issues. But also ive had a bad fan on one and ive had to grease it a few times to keep it spinning with out issues.
What cooler does it run, and what brand is it?
374 (0.07/day)
Netherlands
Processor Core i5 4690K @ 3.5 GHz \\ C2Q Q6600 @ 3.4 GHz
Motherboard Gigabyte GA-Z97X-Gaming 3 SLI \\ Asus P5K Deluxe
Cooling Thermaltake Water 3.0 Performer \\ Xigmatek Dark Knight
Memory Crucial Ballistix Sport 2x 4GB \\ Corsair XMS2 2x 2 GB
Video Card(s) GIGABYTE GTX 970 G1 Gaming v1.1 (Hynix) \\ Sapphire HD 6850
Storage Kingston SV200, 3 TB Seagate 7200.14 \\ 2x 320 GB WD Blue
Display(s) LG 24MP56HQ
Case Corsair Carbide 200R Windowed \\ CM 690
Audio Device(s) Realtek ALC1150 \\ Audigy 2 ZS
Power Supply Adata HM850 \\ Corsair HX520
Mouse Logitech G602, SteelSeries Sensei Raw Frostblue, Corsair M65
Keyboard Logitech Media Keyboard Elite
Software Windows 10 Pro x64 \\ Windows 7 Ultimate x64
well, I had a XFX 8600GT which had a noisy fan which constantly runs at 100%. So I replace the stock gpu-fan with a relatively cheap Zalman vf700 and after that it ran so much cooler and quiet, yes, even when I put the fan on 5V. If I remember it correctly, the temperture were around the 40°C when idled, when running furmark it was around the 70°C and in actual games the card was around 53-60°C (depending on the game), the fan is put on 5V (silent mode) and the videocard was in a Silverstone HTPC case where the airflow wasn't quite optimal, so I guess in a better PC case the temperature would be even lower.
So perhaps replace the stock gpu-fan with a custom gpu cooler, it doesn't have to be a Zalman. Arctic Cooling have some cost-efficient gpu-cooler models, for example this one:
http://www.arctic.ac/en/p/cooling/vga/23/accelero-l2-pro.html?c=2182
FreedomEclipse
~Technological Technocrat~
24,780 (3.76/day)
(currently) Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
+1 on this one.
the Accelero L2 Pro is pretty cheap and should improve temps quite drastically for that 8600GT.
it also comes with step by step instructions which are real easy to follow. all you really need is some rubbing alcohol to get the old thermal grease off and away you go. Accelero coolers come with MX-1/MX-2 thermal paste already Pre-applied so theres no need to get your hands dirty.
Just follow the instructions and everything will be fine
9,923 (1.80/day)
Jakarta, Indonesia
Case Icute Super 18
i have msi 8600 gt and i never had problem with heat.
i just lap the hsf, place new paste and add little oil on the fan, it still run fine until i switch into new graphic card
