Gforce 7800 suddenly doesn't work after a simple dvd-rom change
Gupadindi
12 (0.00/day)
hello,
about a few days ago I wanted to install print shop 23. My dvd-roms(2 of them) both were too slow to read this disk, so i bought a new one. I switched a dvd-rom out for the new one but when i started up my computer there was no response from the monitor, but the graphics card fan was still running and yes the monitor was plugged in. when i took out the graphics card to see if the built in avg(i think that's what its called) was used it worked...so i inspected my graphics card...cleaned it up a little, as far as the dust goes, and looked for any loose parts or missnig pieces from it, but with no luck.
so my question is, could there be a logical answer to why it is not working besides it could be broken?
I dont know if you needs specs or not or which...just ask and i shall provide.
Quick question: Did you turn off your psu when you did this, meaning did you flip the switch and unplug the power cord? Because whenever I turned off my psu to do anything to my computer, I have to clear the cmos when it start it up again or otherwise no matter what I do, I won't get anything but a black screen. But thats with my rampage formula, I dont know what your motherboard is, so I don't know if this happens on yours.
yes i did unplug it completely, there's actually no power switch with this power supply
Might be an OEM PSU. Is this an OEM PC? You might've already been pushing it with that card in there. Maybe this is one power-sucking DVD Drive. XD
errrr...are you saying changing the hardware could push it over the edge b/c it was already at the power maximum?
Oh here's some great info for you...I got 3 beeps when i start this up with the graphics card plugged in XD
I would try and see if your computer works with the old drive, because if it doesn't, then the card is dead, but if it works, it could be your psu like zithe said or something else.
so i should restore my computer to its formal state? I didnt even know DVD drives could effect a computer =(
I have never heard of it either, but its worth testing to see if your card is dead or not
I think your RAM isn't in all the way.
you guys are really going far out with your theories :p
have you checked if you knocked out or forgot to plug back in the 6 pin power cable to the graphics card? many times a gpu fan at full speed and no display can be caused by insufficent power.
lol I had assumed he had checked, but I guess i shouldn't have assumed it :banghead:
The 6 pin power cable connects to your graphics card to power it. Not all graphics cards have it (depending on power draw) but most do, and if yours does and you didn't plug it in, then it won't work
Never heard of a 4 pin for graphics, only heard of 6 pin pci-e (but i have only been building computers for about a year, so if it its really old stuff i wouldn't know) but there is 4 pin that plugs into the motherboard
He might be thinking of 4 pin molex. Some people have to resort to Molex-6pin adapters. He might've disconnected the adapters or something like that.
oh OK that...rather than that my graphics card uses the same 4 pins that hard drives and cd/dvd players do, i dont know why its different than what you say but it is...im going t change my dvds back around just to check this.
True
good news and bad...after switching the dvds back my graphic card works...i know hard to believe...but my computer took a freakishly long time to start up =(...but thx for you help
His card is likely agp, I had a 7600gs agp card, and it indeed used a 4 pin molex power connector. Sounds like a weak psu issue, any way you could try a different power supply?
actually no...this thing uses a IBM case that's small as my 21'' monitor so my other/better power supply doesn't fit there and my dad will shit his pants if he sees me running the computer on the desk without a case around it lol
