Hello there,
Long time listener, first time caller.
My system was as follows:
ASROCK p67 Extreme 4 Mobo
i7-2600K (running at 4,000mhz, so slight overclock from stock 3,400mhz)
Cooler Master heatsink
2xGigabyte GTX 770 Windforce in SLI
4x4GB Corsair Vengeance DDR3 1600mhz
Intel SSD boot drive
Corsair SSD secondary drive
WD HD for storage.
Creative fatality sound card
Corsair 850 PSU
I basically had this system since 2012, though upgraded graphics card and hard drive over the years. Was rock solid (though sometimes computer would reset during windows boot, but never thought much about it as it was rare).
About 2 weeks ago, started getting increasing BSODs in Windows 7. BSOD messages were varied, and occurred during random computer activities (internet, game, word processor). Then started getting just straight up hard locks - no BSOD or anything, just system crash. Then started getting trouble booting up with the Mobo show an error code 55 on the Debug panel on the Mobo itself. Error code 55 is an issue with the RAM according to the ASROCK mobo users manual. So tested each RAM stick individually using memtest86 and no issues were found. Tested the PSU with a Dr.Power device - all checked out.
BSODs and boot failure with Code 55 kept happening. Took off the overclock on the CPU back to stock speeds, same issues persisted.
Finally decided to take things apart and put them back together. When I removed the CPU, I noticed that there were some bent pins on the mobo socket and figured this must be the source of the problem (though hadn't been a problem for 2-3 years).
So got a new mobo, the ASROCK z77 Extreme 4. MOBO came yesterday, so I installed everything again. Boot the system - goes into error code 55!!! Put in only two RAM sticks at A2 and B2 slots (as suggested in the user manual), system boots fine and goes through some Prime 95. Put in all 4 ram sticks, system boots fine and goes through some Prime 95. Re-introduce overclock to 4,000mhz on the CPU, system boots fine and goes through some Prime 95. Temps are always more than OK. Go to sleep with a tentative (though confused) grasp on apparent success.
Boot system this morning - Error Code 55!!!! System won't boot.
So, we know it's not the Mobo. Is it the CPU or the RAM? I'd like to think it's the RAM because that's the cheaper fix, but I am wondering if the CPU is failing; perhaps the bent pins created a slow burn for it to eventually malfunction.
Any ideas to help me decide the next step here?
WD HD for storage.
Corsair 850 PSU
