GIGABYTE AORUS WATERFORCE X II and WATERFORCE II Liquid Coolers Up and Running at CES 2024
GFreeman
1,483 (2.45/day)
GIGABYTE also brought its new AORUS WATERFORCE X II and WATERFORCE II Liquid Coolers to CES 2024, showing all those new features including the Fan EZ-Chang for fans, rotatable water block design, all new upgraded pump and more.
Available in 360 mm and 240 mm versions, both the AORUS WATERFORCE X II and WATERFORCE II will be available in black and the popular white color option (ICE), feature universal design for fan and pump RPM control which makes them compatible with all motherboard brands, new fan blade design increases both airflow and pressure while reducing noise, and the Fan EZ-Chain feature, which allows fan daisy-chaining for easier connectivity and much better cable management. The AORUS WATERFORCE X II comes with LCD Edge View, which is a circular LCD screen on top of the pump while the AORUS WATERFORCE II sticks with the RGB AORUS logo.
GIGABYTE was keen to note these support both Intel 1700, 1200, and 115x and AMD AM5 and AM4 socket motherboards, and go well with the rest of the GIGABYTE's white lineup as it was proudly showcased at CES 2024 show.
543 (1.11/day)
Spain
System Name Gungnir
Processor Ryzen 5 7600X
Motherboard ASUS TUF B650M-PLUS WIFI
Cooling Thermalright Peerless Assasin 120 SE Black
Memory 2x16GB DDR5 CL36 5600MHz
Video Card(s) XFX RX 6800XT Merc 319
Storage 1TB WD SN770 | 2TB WD Blue SATA III SSD
Display(s) 1440p 165Hz VA
Case Lian Li Lancool 215
Audio Device(s) Beyerdynamic DT 770 PRO 80Ohm
Power Supply EVGA SuperNOVA 750W 80 Plus Gold
Mouse Logitech G Pro Wireless
Keyboard Keychron V6
VR HMD The bane of my existence (Oculus Quest 2)
Am I imagining things or is there a big uptick in mostly white products?
190 (0.08/day)
The lightning gives a beige color on first sight. Thought they were meant to combine with noctuas at first lol
