Gigabyte GTX 1080 Turbo OC Memory stuck at 405 Mhz after vbios update from official site!
fra98_
8 (0.00/day)
System Name Desktop-PC
Processor Intel i5 6500
Motherboard MSI Z270 A-PRO
Cooling 7 fans
Memory 16 GB
Video Card(s) GIGABYTE GTX 1080 TURBO OC
Storage 1250 GB
Display(s) Viewsonic XG2401
Case Sharkoon TG5
Power Supply XFX 500 W
Mouse Logitech G402
Keyboard KLIM Domination
Why would you upgrade the VBIOS in the first place? The issue seems to be an incorrect VBIOS flashed
You're right! Kinda a noob sorry, I thought it was the right thing to do with a new card
Updating a VBIOS is entirely unnecessary, there is no real reason to do so. Before trying what I prescribe next, try and delete/reinstall drivers with DDU. Next, I would try to make sure you have the right VBIOS, boot a USB with DOS and nvflash, and force flash it back.
Tried already with DDU, unsuccesfully, there's only one vbios available on GIgabyte site for my card, I'll try now with DOS
Should have saved the original BIOS.
So, I finally fixed my issue, I'll explain everything I did:
1) After flashing the VBios on gigabyte support page (link below)
https://www.gigabyte.com/Graphics-Card/GV-N1080TTOC-8GD#support-dl-bios
Using the utility integrated into the downloaded zip, the memory clock was stuck at 405 MHz, everything else was fine.
2) I searched for hours for a compatible VBios, nothing was working, the VBios that I flashed initally overwritten the PCI Subsystem ID, so nothing was working, nvflash was only giving me errors (PCI mismatch error)
Found only these VBios
https://www.techpowerup.com/vgabios/202799/202799 (I think this one is newer)
https://www.techpowerup.com/vgabios/203217/203217
The first one is the one from the official Gigabyte page (he broke my card essentially)
The others worked force flashing them using this command on cmd
cmd(as admin): nvflash64 -6 biosfile.rom
3) We skipped the PCI check and overwritten the existing one, and it worked! The card runs great and at its full potential!
Thanks everyone for the support, hopefully someone will find useful my experience!
Neh we knew all this before but we thought you knew it too.
I didn't, so probably other people out there don't know
Nevermind him , thanks for the update to your thread, anyone finding it will also appreciate it if they need help.
