- Jan 2, 2016
- 6 (0.00/day)
- New Zeland
System Name | Misko |
Processor | Intel Core i5-3470 3.2GHz 6MB |
Motherboard | FOXCON H61MXE-V |
Cooling | Stock Cooler Intel/DeepCool LED fan |
Memory | 2x4GB Kingston Hyper X 1600MHz (Black+Blue stick) |
Video Card(s) | GIGABYTE GeForce GTX 960IX-0C/2GB GDDR5 |
Storage | 2x Seagate Baracuda 500GB (1TB) 7200RPM |
Display(s) | NemQ GW2270 2x HDMI 1080p/Asus VW192S/FUEGO LED TV HDMI |
Case | *** |
Audio Device(s) | *** |
Power Supply | Antec VP450-P/450W Real Power |
Mouse | GIGABYTE |
Keyboard | A4TECH LED |
Software | Windows 7 Ultimate x64/SP1 |
Benchmark Scores | Unigine Heaven 1920x1080p EXTREME Score: 812 FPS: 32.3 |
Hello guys i cant fix this problem for 5 months so i thought you could help me.
-On August 2015 i have bought a new Gigabyte GTX 960IX-OC but i had 350w GOLDENFIELD chinese psu and i could not run the gpu,i mean i was using the pc just for youtube/facebook etc..I was not gaming because the pc was shuting down.
-While i was using the goldenfield psu my pc was connected to the TV Fuego 1080p using HDMI.(I have not connected my old ASUS monitor)
-After 2-3 weeks i have bought used CM B700w and in games i had bad fps frops and gpu usage was going from 99% to 0%.After some time i have spotted some liquid coming from the psu and BAM broken electrolyte.There were some liquid drops on the mobo and the GPU and i have cleaned them later.
-Before i notice the broken psu i have conected my 9yr old monitor to my pc using DVI-VGA adaptor and i could nnot set my nattive resolution 1440x900p 16:10 75Hz.I was using it on 1280x1024p 60Hz.I had flicker on screen too if i lower on higher the resolution and the HZ.
-I was using the PC with the CM for one week than returned back to the seller and finally bought a new Antec VP450-P psu with 450W Real Power.There was no problems at all
-I have connected my pc to my HDMI tv and everything was working good,there were some fps drops sometimes in games and big stutter like in COD Black Ops 3 and GTA V but i thought the problem is the ram and i have upgrade it to 8GB.
-Every 2nd week i am conecting my pc to my TV 1080p using HDMI for 2-3 days than i get back to my analog monitor.Black Ops 3 is still unplayable,GTA V is crashing at 6005MB ram usage.....
-I went to service with my pc and thay told me that the analog monitor is 16:10 and its too old to give the native res using with GTX 960.Also i did not mentoned that my analog monitor sometimes is shuting down and i have to pull the Power cable and plug in again to give me signal while the pc is working...-this is bad i know.
-Today i have conected to my 1080p TV and problems again, Cant open Photoshop,Run gpu test + AGAIN i have spoted liquid drops all over in my case.WTF again the PSU?
-Question is WHAT THE FUCK IS WRONG WITH MY COMPUTER AAAAAAAAAAAAAA!?
-In some games like Test Drive Unlimited 2 that is 5years old game i CANT GET 60 FPS max 1080p and my gpu load is not 99% WHY ?
-In cities skylines same shit gpu laod 77% fps 44 on medium-high WHY IS GPU LOAD NOT GOING TO 99%?
-This is the result and i did not have any crashes while the test was runing + from the gpu some strange diferent noise were coming....
Why the POWER CONSUMTION IS NOT 99% ? (or it sholud not be 99%
Why in some games the gpu load is not goin on 99% and i cant reach 60fps or more ?
