Good courses on fundamental networking (IP, Frames, OSI layer, subnetmask etc) - please help.
  • Thread starter Thread starter Deleted member 189968
  • Start date Start date
Hi guys,
I'm looking for a solid in-depth networking curses explaing networking such as (LAN networks, Routing, IPv4, IPv6, Frames, Subnet mask, OSI layer etc.) with
a lot of practical expamples (practical typical real life situations to give you an idea of "when is this used?" "why used used?" "what's the point?" )
I do like when courses give a lot of examples such as
*how would this look in a typical Home LAN setting? how are data packages sent? What is contained in the Frames that are sent?
Explain things in a context that makes sense with enough detail to use it in real life /practical situations.
* "When data is sent from your computer to another let's take a look at what happens inside the eithernet cable, and let's understand why a Gateway is needed
to go beyond LAN etc.
* Use windows / OS to show how it looks in real life
* have good animations
My goal is to understand networking and the internet in general (how it works and why) and basic online internet security, and maybe take a Comptia Certificate or
some other computer certificate.
I did find some courses, that I'm considering:
A Free course i found
Free Microsoft course on netorking (looks like it lacks much visual and is quite slow pase)
Free CCNI
Networks already are cursed! ;)
We don't know where you are, but I would sure recommend checking out "courses" offered by your local community college. Many of these will be on-line, classroom, or a combination of both. No, they are not free, but the certification you get is worth much more than the piece of paper it is printed on when it comes to résumé/CV material. Plus, being able to interact with the instructor(s) and fellow students can be invaluable - not just for the learning opportunities and experience, but for the "personal network" of peers, colleagues and contacts you build in your field of study, and job market.
Ely seems to explain things in plain terms, its certainly not a course but it helps you...
ely the Computer guy
hi m8,
All the staff in my group are either Cisco CCIE's or CCNA's.
Cisco CCNA courses are a good starting point, especially for WAN/LAN etc.
Do web searches using - internetworking.
Good luck.
Check stacksocial via slickdeals for the ccna lifetime course, you just missed out on the last 80% off code.
I appreciate the Feedback so far!
I've noted
Keith Barker's videos
Cisco CCNA
Eli (i do find him a bit too slow pase for me)
I also considdered CBT nuggets courses
and
professormesse
I do need courses that show via Wireshack or interactive Windows command promt or settings how to apply
what I'm learning about networking, or else it makes no sense to learn. If i can test it on my own home network via cmd
or see examples it's easier for me to learn, but I try to youtube those examples at this point :)
I've noted
Cisco CCNA
and
professormesse
If I can find them and shipping isn't expensive, I'll send you my old course books. Just return the favor by sending them to someone else someday. Chances are, I don't have then anymore.
That's is so kind of you :) Which course book are they?
ACM
It's $42 a year but you can learn pretty much anything machine, electronic or any IT.
Lots of ways to get it free...Being a Citizen of Brazil gets you a free membership for a year...
"Working" at the moment but they would have been from my intro/advanced networking courses from 5 to 7 years ago. I gave a bunch of them to thrift store a few months ago but not sure which ones.
Introductory networking hasn't changed that much since then so they should still be useful.
Edit: Almost forgot, check out edx.org:
https://www.edx.org/course?search_query=Networking
