Good ram cooler... intel stock fan?
4,686 (0.75/day)
System Name Obelisc
Processor i7 3770k @ 4.8 GHz
Motherboard Asus P8Z77-V
Cooling H110
Video Card(s) GTX 780 Ti
Case T81
Software Win10 64bit
I took the fan and struts off the stock i7 cooler for a photo contest and realized it fits perfectly over all 6 ram sticks. I don't know about mounting, but it occurs to me this will not only move way more air than after market ram coolers but it should also be pretty much dead silent. You could probably mount it with a fat rubber band going back around the ram locking clips and the the legs of the fan. A 775 fan might better fit boards with 4 slots.
swistak92
96 (0.02/day)
Sydney
System Name Beast
Processor AMD Phenom X4 II 965
Motherboard Asus M4A89GTD-PRO-USB3
Cooling Stock
Memory 2x 2G G.Skill-Ripjaws 1333
Video Card(s) 1x Powercolor 5850 PCS+
Storage WD GREEN SATA 1TB
Display(s) LG W2486L-2 x HDMI
Case Coolermaster 922 HAF
Power Supply Corsair TX750W
Software Windows 7 64 Bit
Wooow thanks for the idea!! I was about to order a $50 cooler for my ram.. but now I can put my old fan to use!
Thanks!
9,899 (1.66/day)
Essex, England
System Name My pc
Processor Ryzen 5 3600
Motherboard Asus Rog b450-f
Cooling Cooler master 120mm aio
Memory 16gb ddr4 3200mhz
Video Card(s) MSI Ventus 3x 3070
Storage 2tb intel nvme and 2tb generic ssd
Display(s) Generic dell 1080p overclocked to 75hz
Case Phanteks enthoo
Power Supply 650w of borderline fire hazard
Mouse Some wierd Chinese vertical mouse
Keyboard Generic mechanical keyboard
Software Windows ten
Unfortunately 775 stock fan is too wide for 4 slots, was the first thing I looked at for ghetto cooling my ram.
Then I made this instead.
174 (0.03/day)
San Diego,CA
System Name addiction
Processor i7 920 @ 4.0 Ghz 1.19v
Motherboard EVGA X58 SLI
Cooling Zalman 9700
Memory 3 x 2 GB 1600 mhz OCZ Ram
Video Card(s) EVGA GTX 280 supeclocked
Storage WD Black 750 GB
Case Antec 300
Power Supply Corsair TX850
Software Windows 7 Ultimate
just buy the corsair ram cooler. you can find them for 20 bucks. anyhow +1 on effort and determination!
how did you make it?
9,899 (1.66/day)
Essex, England
System Name My pc
Bending and cutting aluminium and fixing rubber edging to the device, fan is attached with rubber bolts.
Also this wee thing moves as much air as a corsair cooler but with half as much noise :]
NAVI_Z
253 (0.05/day)
System Name Gamer Rig
Processor AMD Phenom II X4 965 BE
Motherboard ASUS M4A78T-E
Cooling Corsair H-50 cpu cooler.Kingston Hyper X ram cooler
Memory Corsair Dominator DDR3 1600
Video Card(s) XFX HD 5870 XXX Edition
Storage WD Velociraptor 300gig ; SAmsung Spinpoint 250gig
Display(s) Samsung SyncMaster 2494 24 inch full 1080p
Case NZXT TEMPEST AIRFLOW KING
Audio Device(s) none
Power Supply Kingwin 800w modular
Software Win 7 Ultimate 64 bit
174 (0.03/day)
San Diego,CA
Cooling Zalman 9700
Case Antec 300
when i installed my corsair ram coolers i really couldnt hear the fans at all. you got the version with 3 i believe 40mm fans and the one with 2 60mm fans. i have the 2 fan one and its awesome!
NAVI_Z
253 (0.05/day)
yeah. got the Kingston Hyper X ram cooler with dual fans.
8,519 (1.35/day)
Kansas City
System Name The Dove Box Rev 5.0
Processor 9800x3D
Motherboard Asus 870E STRIX
Cooling Custom Water
Memory 32 GB 6400 MTs
Video Card(s) Asus 3080 TUF
Storage 2TB Crucial T705
Display(s) 32" LG 1440p 180hz
Case Lian Li O11 Dynamic
Audio Device(s) ON BOARD FTW
Power Supply Corsair 1000W
Mouse Corsair something
Keyboard Steelseries
Software Win 10 64x
Never thought about this, but it's actually a good idea. I've got two i7 stock coolers I could try this on.
I'm definitely not buying the new Corsair fan w/LED's for $50. Geesh
901 (0.16/day)
NYU
System Name Baby Box
Processor i5 4670K @ 4GHz
Motherboard Asus Z97I-PLUS
Cooling Corsair H100i
Memory 16GB Kingston HyperX FURY DDR3 1600MHz @ CL10
Video Card(s) EVGA GTX 780 Dual FTW w/ EVGA ACX Cooler
Storage Crucial M500 240GB SSD (Boot Drive); Seagate 7200.12 1TB 7200RPM (Storage)
Display(s) ASUS VH222H 21.5" 1920x1080
Case Corsair 250D Mini ITX
Audio Device(s) Audioengine D1 DAC/Amp
Power Supply Cooler Master GX RS750 PSU
Mouse Corsair SCIMITAR RGB
Keyboard Corsair Vengeance K70 RGB
Software Windows 10 Pro x64/ Linux Mint 17.3
http://img231.imageshack.us/img231/8678/p1000673b.jpg
That's a really cool way to cool the RAM, I never thought of that. Nice one. :toast:
hat
Enthusiast
21,753 (3.23/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
Is this really nescessary? How hot does RAM really get? My heatspreaders barely get warm at 2.15v...
OMGH4X!
46 (0.01/day)
Processor AMD PHII X4 955
Motherboard M4A79XTD EVO
Cooling Hyper 212+
Memory Corsair XMS DDR3 2GB (2x1GB) CL9
Video Card(s) HIS HD5770
Storage WD6401AALS
Display(s) Dell E771a CRT 1280x1024
Case CoolerMaster 690
Power Supply Corsair Tx650w
Software Vista SP2
I always thought ram had a much lower heat tolerence than, say, a CPU; Could be wrong though..
Anyway, even if the cooling is necessary, it's debatable how much cooling after-market ram fans provide because ram isn't designed to be actively cooled... otherwise it would be covered in (a) heatsink(s), not just a heatspreader
Too bad there's no real way to moniter the temps D:
CDdude55
Crazy 4 TPU!!!
8,178 (1.26/day)
Virginia
System Name CDdude's Rig!
Processor AMD Athlon II X4 620
Motherboard Gigabyte GA-990FXA-UD3
Cooling Corsair H70
Memory 8GB Corsair Vengence @1600mhz
Video Card(s) XFX HD 6970 2GB
Storage OCZ Agility 3 60GB SSD/WD Velociraptor 300GB
Display(s) ASUS VH232H 23" 1920x1080
Case Cooler Master CM690 (w/ side window)
Audio Device(s) Onboard (It sounds fine)
Power Supply Corsair 850TX
Software Windows 7 Home Premium 64bit SP1
True.
RAM really just gets warm, but rarely does it actually get hot. Then again, you really want to have the RAM cooled as best as possible, and to some, they need/want to have a big ass fan or two sitting on top of the sticks. Especially if you do a lot of RAM tweaking/overclocking, good cooling is essential.
I personally just have a 120mm fan sitting at the top of my case that pulls the heat of my RAM sticks. And really, that's all any normal clocked/slightly overclocked RAM would really need.
4,686 (0.75/day)
System Name Obelisc
Cooling H110
Case T81
If you're water cooling and say running DDR2 above 2.2v I'd recommend an air cooler for your ram. But I'd really recommend something free or cheap. I wouldn't fork out $20 for some noisy little 40mm kit.
3,016 (0.51/day)
vermont
System Name The wifes worst enemy
Processor i5-9600k
Motherboard Asrock z390 phantom gaming 4
Cooling water
Memory 16gb G.skill ripjaw DDR4 2400 4X4GB 15-15-15-35-2T
Video Card(s) Asrock 5600xt phantom gaming 6gb 14gb/s
Storage crucial M500 120GB SSD, Pny 256GB SSD, seagate 750GB, seagate 2TB HDD, WD blue 1TB 2.5" HDD
Display(s) 27 inch samsung @ 1080p but capable of much more ;)
Case Corsair AIR 540 Cube Mid tower
Power Supply EVGA GQ1000W MODULAR
Mouse generic for now
Keyboard generic for now
Software gotta love steam, origin etc etc
Benchmark Scores http://hwbot.org/user/philbrown_23/
when I was reviewing the ballistix with temp sensors, no matter what the voltage 1.5-1.9v they got no hotter then 39c just food for thought
3,359 (0.56/day)
System Name Panda? Storm Trooper?
Processor AMD 9950X3D
Motherboard Gigabyte Aorus Pro ICE X870E
Cooling AC Core 1 CPU Block | Heatkiller Radiators 2x 360-45mm 1x 240-30mm |AC Core 120mm Reservoir
Memory G.Skill Trident Z5 64GB CL30 6000Mhz
Video Card(s) RTX 5090 32GB Palit Gamerock w/ Alpha Core Waterblock
Storage 4TB WD Black NVME Gen 4 + 14TB WD HDD
Display(s) ASUS PG32UDCP 32" WOLED 240hz/480hz
Case HYTE Y70 Panda + ColdZero AF Front Panel
Audio Device(s) 2i2 Scarlett Solo + Schiit Magni 3 AMP
Power Supply ASUS Thor III Platinum 1200w
Keyboard NEO75CU White + PBTFans Neon R2 Glitter + BSUN Macaron Switches
THANKS dude, but my RAM doesn't need cooling so I'm using it for my NB instead :). Not using any adhesive or such, just wrapped the wires so it doesn't fall off :toast:
