Gpu cooling and noise
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
I have a pair of Noctua Chromax NF-A14
yea, i have those too, theyre not great fans.
not the redux, or chromax, with rainbow sprinkle color accents, just the traditional, beefy bearing, chocolate milk noctua's
im talking about good fans
if you buy loud looking fans, theyre going to be loud sounding too:laugh:
joking aside, if the fans i linked are 'loud' to anyone who doesnt have their head inside the case, then that is a sign of unrealistic expectations in combination with PC cooling.
8,245 (2.09/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
3-exhaust, it sounds obvious, but ive seen many PC's, with 'exhaust' fans, that are facing inward.
This is a good chuckle, we've all seen this happen. I personally like the pull-pull fans on a radiator. :D :rolleyes:
I recently tried a new (for me) software fan controller called FanCtrl. Does as well as SpeedFan (now abandon-ware) did and is actually updated with some regularity.
15 (0.01/day)
Processor Intel I5 10600kf 5.1ghz
Motherboard Gigabyte z590 gaming x
Cooling id cooling auraflow x 240
Memory Hyperx fury 16gb
Video Card(s) Sapphire Pulse RX5500XT 8gb
Storage 250gb wd black ssd
Display(s) Curved samsung 24" 144hz
Case Deepcool matrexx 70
Power Supply Gigabyte p750gm
I have a be quiet! Pure Base 500DX (which has a mesh front) and three Silent Wings 3 140mm PWM High-Speed fans, also from be quiet. Two front intakes, one rear exhaust. Top of the case is closed with a noise insulated top. The fans are installed with rubber mounts and pushpins to minimize vibrations.
Due to the optimized airflow of my case, and it being overall more cramped than your average midtower, I'm able to keep my intakes at 800rpm max and my exhaust at 900rpm during gaming. The fan on my CPU cooler, the NH-D15S Chromax Black, is also about 600-900rpm. All of this keeps both my GPU and CPU under 65C even in a demanding game.
The fans, due to how they're made and the mounting mechanism used, are incredibly quiet. My case fans are now as loud in gaming as my previous case fans were at idle. Meaning very quiet.
Before getting these case fans, my old Pure Wings 2 (which are low end fans not suited for a build like mine) had to spin up to 1000-1100 RPM to keep my components cool, and even at 900rpm the noise bothered me. No rubber mounts, no rubber frame, and it being installed with screws also sent a ton of vibrations through my case, amplifying noise. It was unbearable, even making me put off gaming sometimes and just go to YouTube. Not anymore with these new fans though.
Takeaway here is if noise bothers you, the main offender is the case fans. If you get some quality case fans built for silence (like the Silent Wings 3), and configure a more relaxed fan curve, you can find a balance of GPU cooling performance and noise. My gaming experience has been considerably improved when my PC no longer sounds like a jet engine (who would've thought?)
140mm > 120mm when it comes to both noise and cooling performance. Larger fans don't need to spin faster to move the same amount of air as a 120mm fan, thus being quieter.
Of course, if you took off your side panel and the GPU temps didn't improve at all, then the heatsink/fans on the GPU are just not enough to cool the GPU. This was the case with my Zotac 2070 Mini. No matter the airflow configuration, that card always went to over 80C in demanding titles. The massive heatsink and six direct-touch heatpipes on my 3070 Gaming X Trio even allows the GPU to be passively cooled without the fans needing to spin in some modern games maxed out at 1440p.
One more thing, I feel that your ears are more important than your GPU temperatures. If you have to lower case fan RPM to reduce noise, but make GPU temp be a bit higher, do so. Those components can take the heat for years, but you will drive yourself crazy listening to the noise for years. I've also found that RPMs above 1000 do not do anything to the cooling of my components, except introduce unneeded noise. So there are diminishing results here, find the perfect fan RPM for your configuration.
I tried running the fans at speeds that i would consider bearable and what a surprise, the gpu hasn't taken off yet, i tried a lot of games and benchmarks but it's running great, can't wait to get my noctua 140's and see how much i can quiet things down
