GPU crashing with artifacts under load
NoName0815
10 (0.01/day)
I recently swapped the cooler on my gigabyte r9 390 because the stock one is just too loud.
After installing the gpu, i tried running furmark as a test if everything works fine, but my pc immediatly crashed and i could only turn it on again after switching the power supply off and on again. Interestingly, the power LED and the RGB light of my ram were still on and my keyboard was flickering in every color possible, but my CPU cooler (also RGB) had no light on at all.
After I tried to play a game, my PC crashed "slower", or in other words I was able to see that some weird artifacts are happening (white big pixels going diagonal from top left to bottom right)
I tried to find a solution by myself but nothing worked.
My System:
Ryzen 5 2600 (stock)
Gigabyte B450 Aorus M
Ballistix Tactical Tracer (2666 variant, oc 3000)
Gigabyte r9 390 (stock, with Prolimatech MK-26 cooler)
be quiet! Pure Power 10 600w
Durvelle27
6,823 (1.46/day)
Memphis, TN
System Name Black Prometheus
Processor Ryzen 7 3700X
Cooling Thermalright PA120 SE
Display(s) ACER AOPEN 34" 3440x1440 144Hz
Power Supply EVGA 600W
Mouse Logitech Trackman
Keyboard Logitech K350
Software Windows 10 EDU x64
Furmark is the worst software to run on a GPU as it puts a unnecessary load on the GPU. Most manufacturers advise against using it.
Likely issue is the cooler not properly mounted and the GPU is overheating badly causing hardlocks
Did you have this issue before swapping the cooler
NoName0815
10 (0.01/day)
I did not have this issue, but i checked the temps and they stayed und 50°C.
As I said in the original post, I also tested with a game.
19,379 (3.46/day)
Remount that cooler...
...what are temps of the card when gaming? 50C load doesnt seem right at all....for that 250W card...
rtwjunkie
PC Gaming Enthusiast
14,034 (2.29/day)
Louisiana
Processor Core i9-9900k
Are you certain the cooler has made contact with the actual GPU?
Remove it, remove the paste, and replace it, then remount. Also, how is the cooler cooling the VRAM? Is it making contact like the one from the factory likely did?
Finally, please don’t use Furmark after you get this sorted.
  • Like
Reactions: 64K
Durvelle27
6,823 (1.46/day)
Memphis, TN
Another issue i am finding is that with a simple search the cooler you listed doesn't list compatibility with the R9 390.
I also see that cooler doesn't include fans. Did you mount fans to it.
And if the issue wasn't present before cooler swapping then the issue has been caused by the cooler change.
64K
6,773 (1.67/day)
Processor i7 7700k
Motherboard MSI Z270 SLI Plus
Cooling CM Hyper 212 EVO
Keyboard Logitech G105
Artifacting is usually a VRAM issue. My guess without more info is that your VRAM is overheating.
NoName0815
10 (0.01/day)
The cooler does fit on an r9 290, which is basically the same but less vram
The mounting holes actually were pretty perfect if you ask me, and sadly the card doesn't let me check vram or vrm temps
But i also tested th vram with occt, it didn't crash
yes i did, twi noctua industrialppc 3000 fans
Durvelle27
6,823 (1.46/day)
Memphis, TN
You must realize you also have a aftermarket GPU which are not based off reference PCBs so there is a difference.
NoName0815
10 (0.01/day)
As far as i know, gigabyte used the same mounting holes like the reference card
Durvelle27
6,823 (1.46/day)
Memphis, TN
Did you mount heatsinks to the VRAMs
As it has very hot VRAM chips that need to be properly cooled
rtwjunkie
14,034 (2.29/day)
Louisiana
What kind of cooling or contact does that cooler make with the VRAM?
19,379 (3.46/day)
Most gddr6 isnt cooled and works fine without...
Remount...
Edit: which specific gigabyte r9 390 do you have? Product number or link, please.
mounting holes are typically the same, that doesnt mean the cooler fits properly....
Durvelle27
6,823 (1.46/day)
Memphis, TN
NoName0815
10 (0.01/day)
Remount...
as i said, I did the occt vram test and it didn't crash. If that test isn't realistic (in terms of heat) just tell me and i would test in different ways
19,379 (3.46/day)
Durvelle27
6,823 (1.46/day)
Memphis, TN
Gddr5 didnt really need it either. Most memory doesnt at stock...
But from my own personal experience Hawaii was a very hot GPU that used GDDR5 at high high volts to sustain clocks in turn causing the VRAMs to run very hot. Almost all AIBs mounted a heat plate over them to combat this but even than they still ran hot.
rtwjunkie
14,034 (2.29/day)
Louisiana
It’s an R9 390, so GDDR5, I believe. I remember those 380/380X/390 cards ran very warm all around and had high VRAM temps in reviews.
19,379 (3.46/day)
Exceptions arent rules. ;)
Gddr5/gddr6... my statement doesnt change, boys. :)
NoName0815
10 (0.01/day)
since you are so sure that the vram is overheating, is that occt vram test not realistic?
Durvelle27
6,823 (1.46/day)
Memphis, TN
Alright OP this is my suggestion
Take the cooler off and reapply TIM then reinstall the stock cooler. The new TIM will help with thermals. Once installed apply a custom fan curve to combat noise.
Run a loop of uniengine heaven and monitor temps
HWinfo64 will give you temps for VRAMs and Core
NoName0815
10 (0.01/day)
alright will try, but why doesn't gpu Z show vram if HWinfo64 can do so?
13,953 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
I agree Furmark puts an unnecessary load on the GPU, but I note that is the exact the purpose of stress tests.
However, it is like taking your car to the drag strip to see how fast it can go in a 1/4 mile. It is extremely abusive which is why warranties won't cover repairs when it blows up.
Plus, it is a "synthetic" scenario. You would not drive it like that out in the streets. So I also agree, don't do it. Test your card by using it performing the tasks you bought it for.
In the meantime, I agree with rtwjunkie - remove the cooler, thoroughly clean the mating surfaces, and reapply a fresh, new, as thin but complete layer of new TIM. Then remount the cooler.
Run the system through a couple of heat up/cool down cycles to allow for TIM curing time. Make sure your case is providing a decent supply of cool air flowing through the case, then use the computer normally and see how it does.
