Hello,
I just bought a second hand graphic card SAPPHIRE PULSE RX 5700 XT. It seems to be running fine, just the FAN is not detected but it is running at MAX as soon as I turn it on. I went to check and saw that a Transistor is missing Q211. But the seller soldered resistors on R213 which is normally empty on normal card.
So on this one, Q211 is empty and R213 has something.
see picture below near the Fan PIN connector
Can anyone help me on find the reference of the missing Transistors?
Thanks
Thanks
