GPU Issue? (running at high clocks )
FireFox
The Power Of Intel
7,507 (1.84/day)
Germany
Processor Intel i7 10700K
Cooling 2x Black Ice Nemesis GTX 480 - 1x Black Ice Nemesis GTX 420 - D5 VPP655P - 13x Corsair LL120 - LL140
Storage Samsung 970 EVO PLUS 500GB/1TB - WD Blue SN550 1TB - 2 X WD Blue 1TB - 3 X WD Black 1TB
Case Corsair Obsidian 1000D
Mouse Logitech G502 spectrum
Keyboard Virtuis Advanced Gaming Keyboard ( Batboard )
Software Windows 10 Enterprise/Windows 10 Pro/Windows 11 Pro
hi all.
can someone tell if it is normal that my GPU is running at 731 Mhz when idle?
this is my second Card
FireFox
The Power Of Intel
7,507 (1.84/day)
Germany
come on people
INSTG8R
Vanguard Beta Tester
8,150 (1.09/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 3
Software Win 11 Pro x64
come on people
It's been like 30min since you posted. Settle down... And stop double/triple posting...
I don't do NV cards so I have no advice other than be patient and wait for someone to answer...
1,407 (0.34/day)
Alabama, USA
Processor 5900x
Motherboard MSI MEG UNIFY
Cooling Arctic Liquid Freezer 2 360mm
Memory 4x8GB 3600c16 Ballistix
Video Card(s) EVGA 3080 FTW3 Ultra
Storage 1TB SX8200 Pro, 2TB SanDisk Ultra 3D, 6TB WD Red Pro
Display(s) Acer XV272U
Case Fractal Design Meshify 2
Keyboard Ducky One 2
Are you running more than one screen? SLI does this sometimes. It's not "normal" so to speak, but it will not hurt the card. Also, you can wait for us to help. Pay me 80k/year and I'll be on call 9 hours a day. Pay me a yearly $100k and I'll be on call 24/5. Pay me $260k/year and I'll be on call 24/7. Otherwise, chill. :p
FireFox
The Power Of Intel
7,507 (1.84/day)
Germany
:roll:
268 (0.06/day)
Europe/Norway
System Name Lava Kitty
Processor intel i7 4930k http://valid.x86.fr/lht7hh
Motherboard Asus x79 deluxe
Cooling H20 Parallel EK D5. Radiator: 480 Monsta 80mm pushpull
Memory Gskill-trident-X 2666mhz 16gb 4x4gb
Video Card(s) MSI GTX Titan X
Storage Samsung 850 pro 512GB. 3GB seagate storage. 1GB storage drive. 4# 300-500 GB storage drives
Display(s) Asus PA279Q, and Asus VG278HR
Case Lian Li PC-343B-XT
Audio Device(s) Asus Essence STX. and. Creative Soundblaster ZxR
Power Supply corsair 1200i
Mouse Corsair M65 RGB
Keyboard Razer black widdow 2013
Software windows 8.1 and soon windows 10
Benchmark Scores ask if u want to see http://valid.x86.fr/lht7hh
its normal, its called gpu boost. it downclocks when idle.
you can force the clock u set it on to be on at all times in precision but it will draw insane alot of power if u leave pc on 24/7.
reason u got gpu boost is since so the card doesnt draw alot of power when not in use, less powerbills to pay
6,871 (1.09/day)
S.E. Virginia
System Name Barb's Domain
Processor i9 10850k 5.1GHz all cores
Motherboard MSI MPG Z490 GAMING EDGE WIFI
Cooling Deep Cool Assassin III
Memory 2*16gig Corsair LPX DDR4 3200
Video Card(s) RTX 4080 FE
Storage 500gb Samsung 980 Pro M2 SSD, 500GB WD Blue SATA SSD, 2TB Seagate Hybrid SSHD
Display(s) Dell - S3222DGM 32" 2k Curved/ASUS VP28UQG 28" 4K (ran at 2k), Sanyo 75" 4k TV
Case SilverStone Fortress FT04
Audio Device(s) Bose Companion II speakers, Corsair - HS70 PRO headphones
Power Supply Corsair RM850x (2021)
Keyboard Logitech Orion Spectrum G910
VR HMD Oculus Quest 2
Software Windows 11 Pro 64 bit
Benchmark Scores https://www.3dmark.com/spy/34962882
No, your cards should not be running those clock speeds at idle. Like Bubbleawesome mentioned, maybe it's something with SLI keeping the cards at those clock speeds. Try disabling SLI.
BTW, this is my single OC'ed GTX 780ti SC at idle-
1,980 (0.39/day)
Mainland Britain
System Name H2o Box
Processor Intel(R) Xeon e5-2690 v2 Stock 3.300 GHz stock
Motherboard MSI X79A-G43 Plus (MS-7760) v3
Cooling CPU EK & Phobya G-Changer 360 V2.0 RAD H2o VGA "AlphaCool M18" Hybrid [pump replaced 18/8/21]
Memory G.Skill TridentX 16Gb 11-12-12-32 2T @ 1866Mhz [locked]
Video Card(s) Zotac GTX 1080ti AMP EXTREME
Storage HyperX Fury 120GB & Savage 480GB SSD, Seagate 250GB,250GB 7200rpm Kingston 64GB SSD
Display(s) Asus TUF Gaming VG32VQR 2560*1440 165Hz VA Panel
Case Corsair O-800D
Power Supply Be Quiet! [Dark Power Pro 11] 1200W CM replaced [7-4-2017]
Mouse Zelotes T-90
Keyboard K66 Mechanical US Layout
Software Win 10 Pro 64Bit v 20H2 / OS [build 19043.1237] WFEP 120.2212.3530.0
Hi
Screenshot from vga cards I am looking at in SLi : power state look fine [just for comparison]
Note: Single monitor with all background applications low or off and no OC application running
atb
Law-II
FireFox
The Power Of Intel
7,507 (1.84/day)
Germany
reason u got gpu boost is since so the card doesnt draw alot of power when not in use, less powerbill to pay
Is not normal and it wasn't the gpu boost or Sli problems, just the 1gpu that run at higher clock speeds even when idle.
Btw I found what is causing this problem,
When I set my monitor at 144Hz refresh
rate The 1gpu Is at high speeds even when idle but when I set the monitor to lower refresh rate 120Hz/60hz the problem is solved...
FireFox
The Power Of Intel
7,507 (1.84/day)
Germany
Your clock speeds when idle are a bit higher than mine (135Mhz)
268 (0.06/day)
Europe/Norway
yeah im used to 950mhz base clock on my 780 classys, and 700 mhz on idle happens time to time but atm its down to 300mhz with latest driver
FireFox
The Power Of Intel
7,507 (1.84/day)
Germany
Yeah bit mine it's just die to the monitor refresh rate.
Now I have my monitor at 120Hz refresh rate and my cards are both 135Mhz while idle
268 (0.06/day)
Europe/Norway
i got same issue with newest driver with my 144hz. but i use my 60hz for gaming.
FireFox
The Power Of Intel
7,507 (1.84/day)
Germany
I had some issues too, I had to uninstalled and reinstalled 3 times the drivers before I got it to work properly.
It's normal that the gpu runs a bit at high clock speeds because with the monitor set it at 144Hz have more work to do...
