Gpu power limit reached
FireFox
The Power Of Intel
7,507 (1.84/day)
Germany
Processor Intel i7 10700K
Cooling 2x Black Ice Nemesis GTX 480 - 1x Black Ice Nemesis GTX 420 - D5 VPP655P - 13x Corsair LL120 - LL140
Storage Samsung 970 EVO PLUS 500GB/1TB - WD Blue SN550 1TB - 2 X WD Blue 1TB - 3 X WD Black 1TB
Case Corsair Obsidian 1000D
Mouse Logitech G502 spectrum
Keyboard Virtuis Advanced Gaming Keyboard ( Batboard )
Software Windows 10 Enterprise/Windows 10 Pro/Windows 11 Pro
hi there.
i have a problem an need some help, i hope someone can help me.
when my graphic card is in full load the GPU shark shows me a warning saying
GPU power limit reached
GPU voltage limit reached
GPU overvoltage litit reached
can someone tell what could be causing such a problem.
here a post a pic
1,927 (0.42/day)
UK
System Name TITAN Slayer / CPUCannon / MassFX
Processor i7 5960X @ 4.6Ghz / i7 3960x @5.0Ghz / FX6350 @ 4.?Ghz
Motherboard Rampage V Extreme / Rampage IV Extreme / MSI 970 Gaming
Cooling Phanteks PHTC14PE 2.5K 145mm TRs / Custom waterloop / Phanteks PHTC14PE + 3K 140mm Noctuas
Memory Crucial 2666 11-13-13-25 1.45V / G.skill RipjawsX 2400 10-12-12-34 1.7V / Crucial 2133 9-9-9-27 1.7V
Video Card(s) 3 Fury X in CF / R9 Fury 3840 cores 1145/570 1.3V / Nothing ATM
Storage 500GB Crucial SSD and 3TB WD Black / WD 1TB Black(OS) + WD 3TB Green / WD 1TB Blue
Display(s) LG 29UM67 80Hz/Asus mx299q 2560x1080 @ 84Hz / Asus VX239 1920x1080 @60hz
Case Dismatech easy v3.0 / Xigmatek Alfar (Open side panel)
Audio Device(s) M-audio M-track / realtek ALC 1150
Power Supply EVGA G2 1600W / CoolerMaster V1000 / Seasonic 620 M12-II
Mouse Mouse in review process/Razer Naga Epic 2011/Razer Naga 2014
Keyboard Keyboard in review process / Razer Blackwidow Ultimate 2014/Razer Blackwidow Ultimate 2011
Software Windows 7 Ultimate / Windows 7 ultimate / Windows 7 ultimate
Benchmark Scores cinebench 15.41 3960x @ 5.3ghz Wprime32m 3.352 3960x @ 5.25ghz Super PI 32m: 6m 42s 472ms @5.25ghz
It's simple don't use Furmark. If your trying to test an overclock use Unigine Heaven or 3D mark.
the54thvoid
Super Intoxicated Moderator
13,592 (2.42/day)
Memory 32GB Kingston Fury
Video Card(s) MSI RTX 5080 Vanguard SOC
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
Many people will tell you to not use Furmark . Let me be the first. EDIT: dammit Buildzoid!
Furmark doesn't test stability as such, more it just pulls as much power as is possible.
Run some standard tests, 3Dmark, Heaven, Valley etc and watch the output on gpu-z or afterburner.
Furmark bad....
1,927 (0.42/day)
UK
FireFox
The Power Of Intel
7,507 (1.84/day)
Germany
it happens the same Problem when i use valley and 3D mark
the54thvoid
13,592 (2.42/day)
Software W10
It's not a problem. Kepler cards have a Max limit. You're simply being told your card has reached that limit.
Monitor your card with GPU-z and run Heaven in window mode. If you watch the log on GPU-z you'll see core speed fluctuations, that's the Kepler limits.
If your temperatures are safe and the cards not over throttling, you have nothing to worry about.
FireFox
The Power Of Intel
7,507 (1.84/day)
Germany
but when i do run a Benchmark and ist finished after a close the program i hear a weird noise coming from the Card and that worry me, i was thinkink if that have something to do with the power supply.
19,381 (3.46/day)
What weird noise? A ringing? That is coil whine and can be normal.
About the only way to get past that power limit is to flash to another or modify the bios... unless you are overclocking, its not worth the risk to me.
