GPU-Z 2.10.0 Cuda Problem
20 (0.01/day)
System Name Nvidia Game Monster
Processor I9-7940X
Motherboard ROG RAMPAGE VI EXTREME ENCORE
Cooling EK-Supremacy EVO RGB - Nickel
Memory Corsair Dominator platinum RGB RGB 32 GB 3600MHz
Video Card(s) Asus Tuf RTX 3080 V2 OC
Storage 30 TB
Display(s) 3x AOC Q27G2U/BK
Case Corsair 900D
Audio Device(s) Astro A50 Wireless
Power Supply Corsair HX1500i
Mouse HP X500
Keyboard Corsair K100 RGB
Hello. :)
i have two Asus GTX1080 Founders Edition in sli..
Sinds the last windows 10 april 1803 update and gpu-z 2.9.0 update my second card haves issues. but my second card works good, only thing is since the windows 10 1803 april update is reading my second card in gpu-z no cuda.
and the nvidia geforce driver, the last one 397.31/397.55/397.64/397.93/398.11/398.36/398.46 dont fixed the problem/issue.
Same with windows 10 updates, bios updates, gpu-z updates.
And in ddu at safe mode, the second card is reading: vbios: no info.
So what is here the problem?..
What i tryed already:
Geforce driver reinstall with ddu and without ddu, older and newer versions.
GPU-Z Older and newer Versions
some other sli bridges
bios updates/downgrades
the card in and out, * watercooling/blocks*
nvidia settings back to default
Bios settings are fine
Getting to the Nvidia Live Service Chat.
p.s with Version Driver 391.35. and GPU-Z 2.8.0 it works.
here 2 pictures,
first picture is first card,
second picture is second card with the problem.
Someone advise?...
Thank u! :)
Someone else posted on here with the same issue.
There is nothing wrong with the GPUs and as long as within the Nvidia control panel both cards shows up as being CUDA enabled everything is fine , it's a GPU-Z bug when SLI is enabled.
yeah iknow, that was me 2 i think.. because i had no reply on my post, so i did a re-post of it.. haha! so you say it,s a gpu-z sli bug?...
No not you , there was another guy with the same problem expect he had 1080tis.
Pretty much.
Oh man you went through all that just to sort this little thing out ? I am curious are you running anything that requires CUDA and SLI and you encountered an issue with it ?
aah okey, can you copy-paste the link/post of it?.. so i can see that post of him.
thank u sir!
Pretty much.
and yes i had ram problems too en motherboard issues.. so i need check everything of it.. but all things are fixed only this thing not.. and yes triple screen gaming.. :) and thnx for the link my bruh! :)
