GPU-Z is not showing 'GPU Load' of my 9500GT
RenanMotta
11 (0.00/day)
São Gonçalo, Rio de Janeiro
System Name RENAN-PC
Processor Intel Pentium Dual-Core E2200 2.20GHz @ 2.00GHz
Motherboard Gigabyte GA-VM900M rev 2.0
Cooling Cooler Master
Memory 1536MB DDR2 @ 533MHz
Video Card(s) Zotac GeForce 9500GT 512MB DDR2 @ default clocks
Storage SeaGate ST3160813AS 160GB 7200rpm
Display(s) PHILIPS 200Vw 20" (1600x900 pixels)
Case N/A
Audio Device(s) Creative SoundBlaster CT-4810
Power Supply C3Tech 350W
Software Windows 7 Ultimate x86
Why the GPU Load of my 9500GT is not being displayed? My driver version is 195.62.
Thanks!
Update to a new driver version? 195.65 is older than dirt.
because your not rendering any 3d graphics? I see the GPU load label on the app.. in 0%, correct me if im wrong, is thats what your asking?
This driver version is not so old and download the lastest driver will take days for me. I will change drivers if needed only.
I ran several games and applications that consumes GPU power and it's still not showing anything. (Yes, I marked the option: "Continue refreshing this screen while GPU-Z is in the background").
And yes, that's what I'm asking.
Thanks!
As I said, upgrade your graphics drivers, I don't believe GPU load monitoring was suppoted or worked properly until the 200 series drivers.
Ok, I will download updated drivers.
Thanks!
Just downloaded and installed driver version 260.99 and everything is working as it should.
GPU load during video encoding:
Thanks!
Glad you got it working.:toast:
