Having to login and enable push note every day.
2,281 (0.94/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. 5950x undervolted . 3. i7 7700hq 4 E5-2699 V3
Motherboard 1.aorus x570 ultra 2. Rog b550 f,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.corsair ven 32gb @3200 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 1tb +1tb , 2 3tb HDs 2. 1tb m.2 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. montech king 65
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2. rog ally 2tb m.2 1tb SD.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847
Having to login and enable push note every day. is this the norm now or is there some thing a miss ?.
This shouldn't be happening. Did you change anything on your side? Can you check with another browser/device?
Maybe some new browser privacy settings?
no i've not changed anything its been doing it for about a week, i'm not keen on trying other browsers unless i really have to mate, i've just try on my other rigg and TPU opens just fine so it looks like its just my main rigg id bet they have updated my edge and broke some thing or turned some thing on or off. thanks.
when i find what it is ill post back.
its deff not anything to do with your end its doing it with flickr, ebay, ect its not doing it with the stargazerlounge. think ive found the problem in edge setting the VPN was turned on and i've never turned it on so i've turned it back off but wont know for sure untill i log in tomorrow.
What browser? You sure you don't have something like this enabled:
Edge bud i think ive found the problem the in built VPN "fingers crossed eh" thanks.
maybe, resetting your browser as the last option
i can tell you all it was Edge's VPN for sure havn't had to do push note since turning the darn thing off, i could of turned it on my self as its right near the x to close edge.
