Heatsink lapping with toothpaste?
237 (0.04/day)
Denmark
Processor Intel Core i7-6700k - Stock, multi core boost enabled
Motherboard MSI Z170i Gaming Pro AC
Cooling Noctua NH-U14S + Arctic MX2 thermal paste, 2 case fans (front and rear).
Memory 2x8gb Kingston DDR4 2666mhz
Video Card(s) MSI Geforce 1060 GTX Gaming X
Storage 120gb Samsung 830 EVO SSD, 240gb Samung 840 Evo SSD, 1tb Seagate HDD, 960gb Corsair Force MP510B
Display(s) Dell Ultrasharp 1920x1080
Case Phanteks Enthoo Evolv ITX SE
Power Supply SilverStone SST-ST85F-P
Mouse Microsoft IntelliMouse Explorer 3.0
Keyboard Steelseries 6Gv2 - Cherry MX Black edition
Software OS: Windows 10 Pro 64bit.
Benchmark Scores Cinebench R20 multicore score: 2249. Cinebench R23 multicore score: 5149.
I know that this trend has kinda died out over recent time, but thought i might give it a go for shits and giggles.
I have this old thermaltake silent viking, and its copper base has recieved quite a beating over the years and years of abuse. I thought i might give the old girl a boost so she can serve me for a few more years in my spare computer.
BUT the only thing i have around is some fine sandpaper (100grit) and standard colgate toothpaste.
I could use the toothpaste alone, but the matter is more of "how".
Google failed me, so how can i lap my old heatsink using toothpaste only?
I have no idea about the toothpaste, but did you mean 100 or 1000 grit? Cuz 100 is not fine, it's the other way around.
add some sand to the toothpaste, you'll be alright
It feels fine to the touch, but i figured that 100 is not nearly enough as you said. Just wanted to underline my predicament :p
I have some gerbil bathing sand :p lol
But can i start out with toothpaste right off the bat? And how should i do it to make sure it gets an even surface?
I figured i could find a piece of clean glass, a dab of toothpaste and rub the heatsink around in circular motions on the glass with the toothpaste?? Or is there a better method?
Toothpaste is not abrasive enough to lap your processor. The sandpaper you need is available at hardware stores or automotive stores.
Its the heatsink i want to lap, not the cpu :p
Upon further inspection the copper contact surface is not as much in a bad condition as i initally thought. Te only problem is that there is a lot of minor scratches around the cpu area, and a lot of thermal grease residue on almost the entire surface, that cant get off even with ethanol/alchohol. The copper plate still retains a mirror finish from factory, it just needs a bit of elbow grease to perfom well again.
Thats why i thought toothpaste would do the job as i had a lot of that within an arms reach.
So the problem was more like how to do it.
The toothpaste has to have baking soda in it, because it's very mildly abrasive, it will act more as a polish at the end of your lap than the actual lapping agent.
start with 240 grit, then 400, 600, 800, 1200, then try toothpaste. and for 600+ you should be wetsanding. use the toothpaste at the very end for a mirror finish (polish)
