- Jan 28, 2007
- 2,648 (0.40/day)
- UK
System Name | Ma Biatch |
Processor | i7 860 |
Motherboard | Gigabyte GA-P55-UD3A |
Cooling | Noctua |
Memory | 8gb (4x2gb) G-Skill |
Video Card(s) | GTX 470 |
Storage | WD5000aaks raid0 |
Display(s) | Sony Bravia 37" 1080p |
Case | CM 690 |
Audio Device(s) | Onboard |
Power Supply | Corsair HX520 |
Software | Windows 7 Ultimate |
ok i have a pracically brand new 250gb sata hdd, i thinks its seagate. anyway it has been forcefully pulled from a machine resulting in the sata power connector breaking, the pins are still in tact, however the plastic backing for them has broke off and i cant find it heres kind of what i mean, the red area (the plastic backing) isnt there, its just the pins: please xcuse my crappy paint job, and it doesnt have the molex power as pictured, only sata
now stupidly i tried using a bit of card behind the pins, just to see if it would work. it wasnt going to be a permanent fix but like i said just wanted to see, it didnt, i need somthing non conductive that i can superglue to the back of the pins or similar so the power cable stays on and flush. any ideas ?
also thinking maybe if anyone has an old sata drive that doesnt work (must have sata power) maybe you could throw that my way, postage would be covered and maybe somthing extra depending, pm's welcomed.
