Im Cooling now with a watercooler just 40€ and a bit work
Also found a way to flash mod VBios without a hardware programmer but need now some information with oc memory HBM2E yes its E and More power tool. At the moment i run it with round about 1300 MHZ on VII PRO VBios. Someone know what a good setting with MPT for HBM2E also need a curve setting because wattman or normal oc tools not working as long as i didnt place parameters in the vbios. And i dont know how to handle with the Curve. I even read when DPM is deactivated (at workstaion) the card will use highes possible frequenzes will this work for gameing too? So hopefully someone got some exp.
At the pic. is my actual setting and what is possible with MPT im using R.ID drivers so no problem with card limits for now.
