Help! Insanely Slow Boot Time!
54 (0.01/day)
System Name Gaming Rig
Processor Intel Core i7-3770k (@3.5Ghz)
Motherboard Gigabyte GA-Z77-D3H
Cooling Corsair Hydro H60 Water Cooling
Memory 16GB Corsair XMS3 (4X4)
Video Card(s) NVIDIA GTX 780 3GB
Storage Samsung 840 Pro SSD 128GB, Seagate 2TB
Display(s) 3x ASUS VS238H 23" Monitors (NVIDIA Surround)
Case Corsair 300R
Audio Device(s) 7.1 Surround Sound
Power Supply Raidmax 850W Gold
Software Windows 7 Home Premium
Hi all,
So I have been having problems with my pc booting from day 1 when I bought it from CyberPowerPC. I have all my drivers installed and Windows 7 running on a 128GB SSD and a 2TB drive for storage. It can take up to 5-10 minutes for my pc to boot, it will get stuck at certain points during booting and I will have to hard boot my pc and switch off the psu and start again. Sometimes it will take just a minute for it to boot, though from my understanding it should be under 10 seconds from an SSD. I am thinking it is a problem with my mobo, please help!
(My full specs are listed under my name on the left hand side)
HammerON
The Watchful Moderator
8,402 (1.42/day)
Up North
System Name Aki
Processor AMD 7800X3D
Motherboard ASUS ROG STRIX X670E-A
Cooling MSI MAG CoreLiquid E360
Memory Patriot Viper Elite 5 32GB 6200
Video Card(s) PNY RTX 4090 XLR8
Case Corsair 5000D Airflow
Audio Device(s) On-board
Mouse Roccat Kone Pure
Keyboard ASUS ROG Strix Scope II Wireless
Software Win 11 Pro
I know when I have my external 2TB drive plugged in, sometimes my boot time slows down. To fix that problem I went into the BIOS and told it to ignore the drive.
You might want to check in your BIOS to see how they have set the boot devices...
But honestly 5-10 minutes probably means something else is slowing it up. At what stage during the boot process does it stall at?
12,340 (2.21/day)
Oregon
Keyboard EVGA / Logitech K400
With an SSD properly installed it takes between 15 and 30 sec. Properly is the key
Typically when you have a hang on boot. (more than two minutes) its hardware related. Most of the time its a piece of hardware not playing along with the system. Not the motherboard but rather a hot swap drive, printer, USB device or drive, web cam, card reader or something like that. First thing I do is start unplugging stuff and see if it stops
One time it turned out to be the sound card. I disabled the GPU sound and it boot correctly
54 (0.01/day)
Case Corsair 300R
But honestly 5-10 minutes probably means something else is slowing it up. At what stage of boot up does it stall at?
It usually stalls at the Gigabyte screen, and I can't access the BIOS because it does nothing when I press the required key.
54 (0.01/day)
Case Corsair 300R
I only have my webcam plugged in though?
12,340 (2.21/day)
Oregon
Did it boot correctly when you got it?
HammerON
8,402 (1.42/day)
Up North
System Name Aki
Software Win 11 Pro
Kursah
Super Moderator
14,764 (2.18/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
You have the most recent BIOS update? Are you sure you're pressing the correct key to enter that BIOS? My Asus boots so fast it came with a utility to reboot directly to BIOS. Well with a dual-boot Linux setup I have most of the fast boot stuff disabled but it's still damn fast.
If you're familiar with the machine, maybe reset the CMOS.
Or even just disconnect the 2TB drive and then do a couple of boots and see what happens.
It's something hardware/setting/detect-wise.
12,340 (2.21/day)
Oregon
Very cool HammerON. I can see that over 7 months my PC has gone from 17 sec to 38 sec
54 (0.01/day)
Case Corsair 300R
The first time it did, but the second time it got stuck at the Gigabyte screen and I had to hard boot it.
54 (0.01/day)
Case Corsair 300R
I'm not sure, I don't think that there is an option in the gigabyte drivers for the BIOS..
12,340 (2.21/day)
Oregon
Press it before the splash screen and not fast. If all else fails disconnect the drive and it will ask you
But if its under warranty call them
54 (0.01/day)
Case Corsair 300R
I bought it a while ago and I have just dealt with it but it had gotten worse, I don't think it's under warranty anymore. I will just disconnect the drive and see what I can do.
9,923 (1.80/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
have you tried to plug out your 2tb hdd, just using your ssd and resetting your bios?
MxPhenom 216
ASIC Engineer
13,172 (2.46/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27ACDNG 360Hz QD-OLED | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" 1440 IPS 1440p
Mouse Razer Viper v3 Pro
I think you might have a memory issue. Have you tried resetting the CMOS? I would also do a BIOS update. You will need to get the most recent one from gigabyte.com. Not from the disc you have given. BIOS updates are not done in Windows, unless that's how Gigabyte wants you to do it.
Im not sure why you didn't just call of CyberpowerPC day one when you were having the issue, let alone, even bothered buying a computer from them.
Solaris17
Super Dainty Moderator
27,612 (3.84/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
Video Card(s) MSI SUPRIM Liquid 5090
Audio Device(s) Moondrop S8's on chitt Gunnr
Keyboard Wooting 80 HE White, Gateron Jades
VR HMD Quest 3
Memory or HDD issue
TRY:
Removing a stick & or
upping the voltage
unplug 2TB drive
Enable staggered spinup in bios (I had to do this)
and see if your boots get faster
54 (0.01/day)
Case Corsair 300R
Ok, I need help getting all the most recent updates for my motherboard. I can't find the BIOS update for my mobo on the Gigabyte website and all of the drivers come in seperate downloads, what a pain! -_-
54 (0.01/day)
Case Corsair 300R
12,340 (2.21/day)
Oregon
look at the board. Its marked on it. Most likely by the PCI slots close to the edge
MxPhenom 216
ASIC Engineer
13,172 (2.46/day)
Loveland, CO
86 (0.02/day)
Houston, TX
Processor i7 4770K
Motherboard EVGA z87 Classified
Cooling Dark Rock Pro 3
Memory HyperX 8gb
Video Card(s) GTX 980 KPE
Storage 1 SSD + 1TB HD
Case Corsair 450D
Audio Device(s) Sound Blaster Recon3Di
Power Supply Corsair AX760i
Mouse G502 PROTEUS CORE
Keyboard Vortex POKER II
Have you tried a clean re-installation of windows? it is possible that there may be an update in process getting "stuck" in the installation process.
Also by re installation I mean CLEAN, not a backup OEM copy. I would also disconnect all drives except the SSD which you are installing windows.
54 (0.01/day)
Case Corsair 300R
Yep I formatted the drive and did a clean install but it did nothing.
155 (0.03/day)
the bad choice is the cpu that has a gpu inside .
all others cpus you can install are below the one you use . boot is long because the mvp virtue is a chipset that hold the intel gpu and the nvidia . it tries to get the "best" mixing them ..... but nvidia can not bear that way : check hyper sli here and hybrid physx : softwares made to patch nvidia drivers...
change the mobo for a lga 2011 or an amd socket if you want to play games or may be 2 ati 2x0 instead of the nv.
54 (0.01/day)
Case Corsair 300R
My board is revision 1.0
The boot was slow before I had a 780, I had a Radeon 6950 2GB instead
