System Name | Apollo |
Processor | Intel Core i9 9880H |
Motherboard | Some proprietary Apple thing. |
Memory | 64GB DDR4-2667 |
Video Card(s) | AMD Radeon Pro 5600M, 8GB HBM2 |
Storage | 1TB Apple NVMe, 2TB external SSD, 4TB external HDD for backup. |
Display(s) | 32" Dell UHD, 27" LG UHD, 28" LG 5k |
Case | MacBook Pro (16", 2019) |
Audio Device(s) | AirPods Pro, Sennheiser HD 380s w/ FIIO Alpen 2, or Logitech 2.1 Speakers |
Power Supply | Display or Thunderbolt 4 Hub |
Mouse | Logitech G502 |
Keyboard | Logitech G915, GL Clicky |
Software | MacOS 15.3.1 |
Not that I'm aware of. Z87 boards aren't going to tend to support Xeons though. I do remember seeing an Intel ITX board with a Q77 chipset though. The performance shouldn't be too far off from a Haswell chip since you won't be overclocking.
Intel BOXDQ77KB LGA 1155 Intel Q77 HDMI SATA 6Gb/s...
Appreciate your reply
Isn't the new Exon v3 cpus are using 1150 sockets? Is Q77 a basically a z77 architecture board?
It is, but if you don't already have the Xeon it shouldn't matter because the performance wouldn't be too far off. I did ask a question though. Do you already have the Xeon or do you have the option to go with 1155 instead?
Edit: It's a little early for 1150 server boards to be cropping up, but there might be an ITX one already. I haven't seen one though.
System Name | Main PC- Gamer- Main Cruncher/Folder and too many crunching/folding rigs |
Processor | Ryzen 5900X- Ryzen 5950X- Ryzen 3950X and etc... |
Motherboard | Asrock X570 Extreme4- MSI X570S Tomahawk MAX WiFi- MSI B450M Bazooka Max and etc... |
Cooling | Noctua NH-U14S (dual fan)- EK 360 AIO with push/pull fans- Corsair H115i RGB Pro XT and etc... |
Memory | 2x16GB GSkill FlareX 3200/c14- 4x8GB Corsair Vengeance 3600/c16- 2x16GB Team 3600/c18 and etc.. |
Video Card(s) | MSI Gaming RX 6800- Asus RTX 3070 TUF OC- MSI Ventus GTX 1660Ti and etc... |
Storage | Main PC (1TB WD SN850- 2TB PNY CS 3040- 2TB Seagate Firecuda) and etc... |
Display(s) | Main PC (2x24" Dell UltraSharp U2414H) |
Case | Phanteks P600s- Seasonic Q704- Fractal Meshify C and etc... |
Audio Device(s) | Logitech Z625 THX 2.1 speakers |
Power Supply | EVGA 750 G3- SeaSonic DGC 750- EVGA P2 850 and etc... |
Mouse | G300s |
Keyboard | Corsair K65 |
VR HMD | N/A |
Software | Windows 10 Pro or Ubuntu |
Benchmark Scores | Why sit on the Bench when you can get in the game and Crunch!!! |
I am planning to get a e3 1265L v3 cpu as they are available for purchasing in some distribution channels that I know.
So instead of staying with the old platform, I am planning to move towards the new haswell one for my NAS.
Thanks again
Check into the EVGA Z87 Stinger itx board- EVGA usually has pretty good Xeon support
First I should say that a Xeon is overkill for a NAS. NAS doesn't require a lot of power and the platform shouldn't matter all that much, so going with a 1150 Xeon is just a waste of money because you'll have no tangible improvement in performance. I would honestly find yourself a cheap ITX 1155 board and a Pentium G2020 if it's only going to be a NAS. Anything more is overkill for serving up files because it takes practically no CPU power to do I/O.
And I believe CPU does matter when using software raid(please correct me if I am wrong).
The box I am planning will holding upto 6 HDD and 1 SSD(for OS and some application, DB and other files will be stored in HDD raid 5).
Again, I heard that any B87, H87 and Z87 itx board will support exon e3 v3 cpus?
Not that much. Any modern CPU can handle software and FakeRAID (like Intel RST) workloads just fine.
So you're probably going to need a PCI-E 8-port (or bigger if you wanted) SATA controller, an ITX board probably won't offer that many ports. There are some cheap RocketRAID ones that I've heard do FakeRAID pretty well.
I keep referring to FakeRAID, just for clarification when I say this I mean; that there is a RAID OpROM but the controller relays RAID commands through the CPU. It doesn't have dedicated hardware for doing RAID, which is the case for Intel RST.
Not quite. It depends on the motherboard manufacturer and the board itself because the BIOS really determines which CPUs are supported on the board. Looking through the list of supported CPUs for any given board will tell you if the Xeon is supported or not. As well as what BIOS revision is required to support it.
System Name | BeeR 6 |
Processor | Intel Core i7 3770K* |
Motherboard | ASUS Maximus V Gene (1155/Z77) |
Cooling | Corsair H100i |
Memory | 16GB Samsung Green 1600MHz DDR3** |
Video Card(s) | 4GB MSI Gaming X RX480 |
Storage | 256GB Samsung 840 Pro SSD |
Display(s) | 27" Samsung C27F591FDU |
Case | Fractal Design Arc Mini |
Power Supply | Corsair HX750W |
Software | 64bit Microsoft Windows 10 Pro |
Benchmark Scores | *@ 4.6GHz **@ 2133MHz |
