- Apr 30, 2017
- 345 (0.11/day)
- USA
System Name | pr0n box, Version 12 |
Processor | i7-14900K |
Motherboard | Asus ROG STRIX Z790-A II |
Cooling | Corsair H150i Elite Capellix XT (360mm AIO) |
Memory | 32GB Corsair Vengeance DDR5-7200 CL34 |
Video Card(s) | 7900XTX 24GB XFX Merc 310 Black -- OC bios 444W ~2800mhz |
Storage | Samsung 990 Pro 2TB NVMe |
Display(s) | Samsung G95SC 49" Ultrawide, 5120x1440p240, HDR10 |
Case | Corsair 3500X with Noctua fans |
Audio Device(s) | Beyerdynamic DT990 Pro, FX-Audio DAC X6, DTS Headphone:X |
Power Supply | be quiet! PurePower12M ATX3.0 1200W Gold |
Mouse | Corsair M65 Ultra |
Keyboard | Corsair K57 |
It's time to retire my trusty old Lian Li PC60 Plus II. My gtx970 heat pipes are too wide so I can't fit the side 120mm fan anymore, my last few gpus have been too long so I had to take out the HDD bay, and I have a hodge podge of adapters and junk to fit my ssd. And it has old 80mm fans that are loud. And most importantly, there's no place to put an AIO cooler that I've decided my i7 would like to have. I like the looks of this Phanteks Enthoo Pro M or P400 case, and pcpartpicker.com says it fits the H110, presumably in the top area.
I am leaning towards the Corsair H110i 280mm AIO. It's cheaper than the H115i and I thought the slight advantage in cooling is worth the marginal price increase over the H100i. Are there any AIOs that are cheaper but similar performance? I would rather not piece together a custom water system, I've never had water before and always avoided it.
Is a 280mm going to fit where a 240mm normally would? Any good cases to recommend for the 280mm? Is a 280mm really going to perform better than a 240mm?
