- Feb 22, 2009
- 786 (0.13/day)
Processor | Ryzen 7 5700X3D |
Motherboard | Asrock B550 PG Velocita |
Cooling | Thermalright Silver Arrow 130 |
Memory | G.Skill 4000 MHz DDR4 32 GB |
Video Card(s) | XFX Radeon RX 7800XT 16 GB |
Storage | Plextor PX-512M9PEGN 512 GB |
Display(s) | 1920x1200; 100 Hz |
Case | Fractal Design North XL |
Audio Device(s) | SSL2 |
Software | Windows 10 Pro 22H2 |
Benchmark Scores | i've got a shitload of them in 15 years of TPU membership |
I have bought 4 DIMM sticks of 2 Gb Kingston HyperX DD3 1333 MHz, rated CL7 at 1.65V
But for some reason by default the work at CL9. So i have to manually adjust them to CL7. But the problem is that there are far more RAM timing and control settings than i understand. Help to to configure my RAM at CL7.
Here are the default settings for 1333 MHz DDR3 CL9:
CAS Latency 9T
RAS to CAS Delay 9T
Row Precharge Time 9T
Minimum RAS Active Time 24T
1T/2T Command Timing 2T
TwTr Command Delay 5T
Trfc0 for DIMM1 160 ns
Trfc1 for DIMM2 160 ns
Trfc2 for DIMM3 160 ns
Trfc3 for DIMM4 160 ns
Write Recovery Time 10T
Precharge Time 5T
Row Cycle Time 33T
RAS to RAS Delay 4T
Now i need to configure the same things to 1333 MHz DDR3 CL7
CAS Latency 7T
RAS to CAS Delay 7T
Row Precharge Time 7T
Minimum RAS Active Time 20T
What about the rest specs?
Motherboard: Gigabyte 890GX, version 2.1
CPU: Phenom II X6 1075T, stepping 0 (no OC)
CAS Latency 9T
RAS to CAS Delay 9T
Precharge Time 5T
Row Cycle Time 33T
RAS to RAS Delay 4T
CAS Latency 7T
RAS to CAS Delay 7T
