Help me improve performance possibly
runna23
13 (0.03/day)
Hi, I have a I7 9750h I have been running these configurations for a while now but I am wondering if there is any room for improvements. I want to run a higher clock of 3.4 ghz but easily overheat if there are any settings or problems you see that is not allowing me to run at higher performance and etc. Please let me know. The log file below is the cpu running apex legends with the settings I linked below.
  • 2025-04-02.txt
    2025-04-02.txt
Try running the TS Bench 960M test. Does it report any errors? Your cache undervolt might be a little too much. If you see any errors in the TS Bench, it would be a good idea to increase the cache voltage until the errors go away. Some 9750H CPUs start losing stability at -125 mV for the cache offset.
You cannot undervolt anymore than what you are already doing. Have you ever cleaned out your laptop or replaced the thermal paste. Try using Honeywell PTM 7950. It might help lower your CPU temperatures so you can increase the turbo ratios back up to full speed. It is either that or move to the Arctic. Your choice. :)
