Predator500triton
- Apr 6, 2022
- 3 (0.00/day)
So this is all new to me. Though I'm not a gamer I do a lot of vid and picture processing. So I have two gaming systems, both maxed with 64gb of ram.
1. a Dell G5 5590 I79750. This was locked from throttle stop in the bios until I unlocked it by downgrading to version 1.1 and resetting. After undervolting successfully
both my gpu and cpu stays in the 60 degrees Celsius range.
2. a Acer predator triton 500 I711800h rtx 3060. Unfortunately the cpu is also locked from TS but the TPL is not. But I'm not sure what values to input in any of the boxes.
So my temps for processing vids or pics with just the internal fans plus a 5000 rpm cooling pad is a decent 79-84 Celsius range. Also an astounding 60 degree range for both cpu and gpu by going into windows "max processor state" in the power plan section and changing the 100% processor usage to 99%.
Of course you lose about 20 fps doing this but thats not a problem with me when I just process pics. But it went from 1 second to process a 1200 x1600 pics to 2400 x 3200 to 3 seconds at 99% processing power. BTW my dell takes 5 seconds to process the same pics with the same program undervolted.
So tell me whats a good base for:
long power pl2
short power pl2
Turbo time limit
speed shift values min and max
power limit 4
TDP level
power balance
ppo power limit
ppo turbo time limit
And what about the main TS window. What should be checked in TS 9.4.
Thanks for your help
long power pl2
short power pl2
Turbo time limit
power limit 4
TDP level
power balance
ppo power limit
