[HELP] New Asus MB boots into EzFlash tool
2,771 (0.57/day)
East Europe
System Name PLAHI
Processor I5-13500
Cooling 120 AIO IWONGOU
Video Card(s) RTX A2000
Case TT URBAN R31
Mouse Logitech Triathlon
Keyboard REDRAGON MITRA
Software Windows 11 Home x 64
Greetings all,
not my system, but a friend of mine. System specs:
MB: Asus TUF B760 Wifi DDR5
CPU: I5-13400
RAM: 1x32GB Transcend DDR 4800Mhz CL40
Drives: 2xPatriot P400 512GB + 1x2TB Kingston NV2
GPU: Palit RTX 3070 Gaming Pro OC
Problem description: parts arrived, we installed CPU, one Patriot drive and the one stick of RAM (no GPU, no more drives for the first boot). System booted immediately. Ram frequency was @4000Mhz, but in yellow
motherboard displayed "auto target DRAM frequency 4800 mhz", I just registered this, but continued to flash the board with latest BIOS from Asus: 1402.
After the flash board booted fine, but straight to Ez Flash utility. Ram frequency @4000mhz and doesn't respond to any changes from the BIOS menu. Installed Windows 11 fine, no errors, but on each boot the
motherboard goes to EZ Flash utility, not the general BIOS menu, but specifically to EZ Flash utility. Ram frequency is also not OK, still sitting at 4000mhz. Once you exit EzFlash utility and click on the boot drive PC
runs fine, plays any game you throw at it, no errors of any kind. In device manager everything is recognized except one Intel Serial IO Drivers, but I will sort it out.
Things I've tried:
- replaced the 2032 battery on the motherboard with brand new
- disabled Fast boot
- checked CSM and UEFI settings.
Things I am about to try: roll back one BIOS back to version 1202.
I will be posting a ticket to Asus support as well, but if any of you have any idea why it goes to EzFlash instead of booting directly I'd more than glad to receive some help.
Thank you in advance for your time.
7,607 (1.44/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
If you have a bios at some root of storage device it will sniff it and usually reboots straight to EZ Flash
2,771 (0.57/day)
East Europe
System Name PLAHI
Processor I5-13500
Case TT URBAN R31
I am sorry, but I am not sure if I understand you right. I had the BIOS file on the same flash drive with the Windows 11, but once the flash is pulled out isn't it going to "forget" about it. Or you mean something else? Should I clear the CMOS with the jumper?
7,607 (1.44/day)
Rīga, Latvia
Software FEDORA 41
If you flashed it. And still left the USB drive in, it will still sniff it and boot to EZ FLASH.
You should always reset and load defaults after flashing any BIOS. ASUS itself recommends it.
2,771 (0.57/day)
East Europe
System Name PLAHI
Processor I5-13500
Case TT URBAN R31
I did load the defaults with F5, but not immediately after the flash. On one of the next reboots I went to defaults. So what now? Have just the .bin file on a flash drive and roll back? See if this solves the issue?
3,696 (0.84/day)
GMT +2
System Name Red Radiance l under construction
Processor 5800x
Motherboard x470 taichi
Cooling stock wrath
Memory TridentZ Neo rgb 3600mhz (2x8 kit)
Video Card(s) Sapphire Vega 64 nitro+
Storage 970 evo nvme
Display(s) lc27g75tq
Case tt core x5 tge
Audio Device(s) sennheiser's pc323d usb soundcard
Power Supply corsair AX860i
Mouse roccat burst pro
Keyboard roccat ryos mk fx
Software windows 10
Jbird
2 (0.00/day)
Hi I had a similar problem and reinstalled the bios, turned out it hadn't finished properly so was waiting for that to happen. Once I had done it it booted just fine.
tig
1 (0.00/day)
ASUS PRIME B760M-A D4
Same issue in attempting to upgrade to 1641.
After my first attempt, the machine worked fine, but would always boot into the EZflash part of BIOS setup. It showed that the BIOS was v1641.
Based on @Jbird's comment, I ran the BIOS upgrade again.
This time it stuck and the machine boots properly.
Gracias.
