Higher-Capacity Flash Memory
HellasVagabond
3,376 (0.50/day)
Athens , GREECE
System Name SECONDARY RIG / PRIMARY RIG / THIRD RIG
Processor i920@3.6GHz / i920@4GHz / AMD Phenom II 955
Motherboard Gigabyte EX58-UD4P / Gigabyte EX58-UD7 / ASRock 890GX3
Cooling CoolIT Domino ALC / Thermalright Silver Arrow / Thermalright VenomousX
Memory 12GB DDR3 @ 1800MHZ / 6GB DDR3 @ 2250MHZ / 4GB DDR3 @ 1600MHZ
Video Card(s) XFX ATI RADEON 5970 / GAINWARD NVIDIA GTX 580 / 2xGEFORCE GTX295
Storage 1550GB / 6TB SAS - SSD / 160GB SSD
Display(s) NEC 26WUXi2 / NEC 3090WQXi / SONY 55A2000 (1080P 55inch)
Case COOLER MASTER HAF 932 / COOLER MASTER ATCS 840 / ANTEC DARKFLEET DF85
Audio Device(s) Soundblaster X-Fi Xtreme Music / SoundBlaster X-Fi Fatal1ty Pro / Realtek Onboard
Power Supply CWT 1200W / Enermax Revolution 85+ 1250W / Ikonik Vulcan 1200W
Software Windows 7 x64 / Windows 7 x64 / Windows 7 x64
Nanosys a new company in the Flash Memory business seems to have found a way to make higher capacity flash memory. That is possible by using self-assembled metal nanocrystals which when added to the flash manufacturing process supposedly double the capacity of conventional chips. MIT's Technology Review stated that the crystals themselves are grown in a liquid solution and then spun onto silicon wafers which may not be an entirely new process but Nanosys has managed to come up with a chemical process that produces crystals which are more uniform in size and spacing than previous attempts by others. That's apparently been enough to attract the interest of Intel and Micron. Nanosys says that they could be putting the technology to use as soon as 2009.
but no idea how much higher capacity?
Well if the current top of the line is 16gb (assuming) then Id wager 32gb is the highest end.
