how do i change my gpu voltage?
3,016 (0.51/day)
vermont
System Name The wifes worst enemy
Processor i5-9600k
Motherboard Asrock z390 phantom gaming 4
Cooling water
Memory 16gb G.skill ripjaw DDR4 2400 4X4GB 15-15-15-35-2T
Video Card(s) Asrock 5600xt phantom gaming 6gb 14gb/s
Storage crucial M500 120GB SSD, Pny 256GB SSD, seagate 750GB, seagate 2TB HDD, WD blue 1TB 2.5" HDD
Display(s) 27 inch samsung @ 1080p but capable of much more ;)
Case Corsair AIR 540 Cube Mid tower
Power Supply EVGA GQ1000W MODULAR
Mouse generic for now
Keyboard generic for now
Software gotta love steam, origin etc etc
Benchmark Scores http://hwbot.org/user/philbrown_23/
How do I change my gpu voltage on my hd4870's using rbe? The highest voltage option I can choose is 1.26v. I really want to overclock them higher than the 800mhz ccc max. Also what is the best way to up my ccc limit using rbe? Thanks for ur help in advance!
Anybody? Is this possible?
I believe you have to volt mod it. Try googling a volt mod guide for your video card.
use ati tray tools or gpu tool, you can override the overdrive limit with it.
Take a read here for some ways of adjusting your GPU voltage.
Some different ways there for altering voltages, try and see which will work for your card.
Be very careful either way you do it, bump it one notch at a time and watch your temps. Also you might not be able to do it, you I believe need the Voltarra WRM cards to be able to software adjust your voltage, and I don't think any of the 512MB 4870's ever had that.
Well ill give that link a once over and see what can be done. I have the his 4870 with the aftermarket cooling and the non reference power color 4870 temps so far are 58c max
