How do I enable port forwarding?
ShadowFold
16,918 (2.66/day)
Omaha, NE
System Name The ShadowFold Draconis (Ordering soon)
Processor AMD Phenom II X6 1055T 2.8ghz
Motherboard ASUS M4A87TD EVO AM3 AMD 870
Cooling Stock
Memory Kingston ValueRAM 4GB DDR3-1333
Video Card(s) XFX ATi Radeon HD 5850 1gb
Storage Western Digital 640gb
Display(s) Acer 21.5" 5ms Full HD 1920x1080P
Case Antec Nine-Hundred
Audio Device(s) Onboard + Creative "Fatal1ty" Headset
Power Supply Antec Earthwatts 650w
Software Windows 7 Home Premium 64bit
Benchmark Scores -❶-❸-❸-❼-
I want to set up a Dedicated server and my friend said I needed to enable port forwarding for people to see my server cause currently no one else but me can. Thanks :toast:
On your Router. Type the address it be some thing like 192.168.1.1 look in the manual of your router. O yeah should have a password in there too maybe some thing like Admin.
O yeah what Router do you have ?..
I got it OEM so no manual. D-LINK EBR 2310
What is your server used for? If it's FTP then forward ports 20 and 21 from the router to your server's internal IP address. If it's a game server then forward that port, etc.
idk about any of this stuff I just want to get my TF2 dedicated server working lol...
forward ports 27015 and 27020
Likely there's more sorry don't play TF2 not my type of FPS.
If it still not working you could try DMZ your router this will open EVERY port for a local IP.
If you want to know your local IP addres use the IPConfig in a dos box.
You might also want to try things like making sure your PC is not set to private, then its invisible. Also, make sure your firewall is not disabling things like file sharing, or stealthing your pc.
