how I use Netgear jnr1010v2 as repeater
21 (0.01/day)
recently I buy Netgear jnr1010 v2 to use as repeating my TP LINK WA5210G v1 SIGNAL.
but after 5 days I can not figure out how to configure as repeater...plz help me..
Set Up a Repeater Unit
Use a wired Ethernet connection to set up the repeater unit to avoid conflicts with the wireless connection to the base station.
Note: If you are using the JNR1010 base station with a non- router as the repeater, you might need to change additional configuration settings.
In particular, you should disable the DHCP server function on the wireless repeater AP.
To configure the router as a repeater unit:
  • 1. Log in to the router that will be the repeater.
  • 2. Select Basic > Wireless Settings and verify that the wireless settings match the base unit exactly. The wireless security option must be set to WEP or None.
  • 3. Select Advanced > Wireless Repeating Function and select the Enable Wireless Repeating Function check box and the Wireless Repeater radio button.
  • 4. Complete the Repeater IP Address field. This IP address must be in the same subnet as the base station, but different from the LAN IP address of the base station.
  • 5. Click Apply to save your changes.
  • 6. Verify connectivity across the LANs. A computer on any wireless or wired LAN segment of the router should be able to connect to the Internet or share files and printers with any other wireless or wired computer or server connected to the other access point.
http://www.downloads.netgear.com/files/GDC/JNR1010/JNR1010_UM_10Aug12.pdf
Male sure to use the same channel a.d channel width as the original router as well
