How many cores render one frame of a pixar movie?
bobesko
67 (0.01/day)
System Name Windows 7 Ultimate 64-bit
Processor Intel i5 2500K
Cooling Arctic freezer rev.2
Memory Kingston 2x4gb Hyperx genesis ddr3-1600mhz cl9
Video Card(s) Msi 6950 2gb flashed
Storage WD 500gb 7200rpm
Case HAF 922
Power Supply Corsair TX650
For example Cars 2 needed a render farm of 12500 cores to render the entire movie. One frame took around 7 hours to render but it certainly isnt those 12500 cores just for one frame. That would be not feasible since it would take thousands years to make the whole movie. So how many render farm cores on average are used for making one frame of a Pixar movie?
cdawall
where the hell are my stars
27,683 (4.04/day)
Houston
System Name Moving into the mobile space
Processor 7940HS
Motherboard HP trash
Cooling HP trash
Memory 2x8GB
Video Card(s) 4070 mobile
Storage 512GB+2TB NVME
Display(s) some 165hz thing that isn't as nice as it sounded
I would probably vary depending on server load. I doubt there are dedicated cores for each frame.
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
All cores are likely used for each frame. They make many passes performing or extending a specific task in the frame. I'm sure the bulk of the processing power is dedicated to lighting. They probably use dynamic lighting on the final render so all the lighting has to be recomputed at every frame.
cdawall
27,683 (4.04/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
They render multiple frames at the same time though...
bobesko
67 (0.01/day)
Case HAF 922
Do in fact all cores dont render one frame for several hours but lets say 50 frames?
cdawall
27,683 (4.04/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
yes otherwise you would never get a movie done.
bobesko
67 (0.01/day)
Case HAF 922
Unfortunatelly Pixar doesnt specify how many cores are capable of rendering one frame in like 10 hours. Not that it matters that much but it would be an interesting information to know.
103 (0.02/day)
Herndon,Va
System Name home build
Processor Core I5-10600K
Motherboard MSI Z590 Pro A
Cooling Cooler Master HF212
Memory 2x8GB DDR4-3200
Video Card(s) Zotac RTX2070 Super Mini
Storage 1tb ssd, 2tbhdd
Display(s) LG 32inch 2560x1440
Case Lian-Li
Audio Device(s) on board
Power Supply 750watt
Software Win 11 Pro 64bit
I would say that the rendering process is dynamic based on what the software wants to get done in a certain amount of time. So maybe the operators don't know how many cores are being used at the time a frame is being rendered.
I mean look at it this way. DO you you really want to sit at a desk looking at a task manager for a 12,500 core rendering farm trying to figure out which cores are rendering which frame. You be there all day chasing ghost.
9,923 (1.80/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
https://renderman.pixar.com/products/tools/faq-threading.html
On a four-core processor you might allocate these four threads in several ways: rendering one frame using 4 threads, 2 frames simultaneously using 2 threads each, or 4 frames at the same time using 1 thread. (Memory permitting)
The simpler new unlimited threading model (RPS v15.0, RMS v3.0, RfM v4.0) will allow each license to use any number of threads. For example, if you have a dual quad machine, then RenderMan can automatically allocate a full rendering thread to each of the 8 processors to render your frame. This model scales simply to upcoming hardware and the entire compute capacity of machines with 16 cores or more can if desired be assigned to a singe rendering session. It should be noted that unlimited threading applies to each license invocation, reflecting the simplified model and current industry trends in application development and usage patterns.
9,899 (1.66/day)
Essex, England
System Name My pc
Processor Ryzen 5 3600
Motherboard Asus Rog b450-f
Cooling Cooler master 120mm aio
Memory 16gb ddr4 3200mhz
Video Card(s) MSI Ventus 3x 3070
Storage 2tb intel nvme and 2tb generic ssd
Display(s) Generic dell 1080p overclocked to 75hz
Case Phanteks enthoo
Power Supply 650w of borderline fire hazard
Mouse Some wierd Chinese vertical mouse
Keyboard Generic mechanical keyboard
Software Windows ten
They've probably moved onto GPU processing these days (hopefully)
3d rendering/lighting is a lot faster on a gpu.
