How restrictive are non-mesh front panels? Let's find out...
4,934 (0.97/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
I was going to place this in the "How many fans do you have on your PC case" thread but decided it could hijack the topic so I created a new thread.
So I had some free time while watching Sunday's games and decided to run some thermal tests on the CPU. Take all results for what they are; unique to my case, cooler, and fans...so obviously they should be taken as gospel for all your airflow /cooling situations.
Stress test used - 20 minutes of Intel XTU. PC was then shut off for 15 minutes to cool off before the next test. I used both Intel XTU and HWmonitor to confirm CPU temps.
Case - Phanteks P400S with dust filters on both roof panels, front roof panel has no fan
CPU - Intel i7-9700k @ 4.9ghz all cores
Cooler - Noctua U12A with both fans set to normal setting in the BIOS (about 1600rpm tops)
Front Fans - two TB silence 140mm @ 750rpm roughly 66m3/h set to full speed setting via BIOS
Top fan rear - Noctua NF-P14r redux set to 950 rpm roughly 90m3/h via BIOS
Rear fan - Noctua NF-S12A @ 1200rpm roughly 105m3/h set to full speed setting via BIOS
My basement office temp was 71F, all other temps below are in Celsius (or centigrade if you prefer)
First test I removed the front panel of the case, the side glass panel, and both roof dust covers. I then continued to place items back on the PC case for each test (i.e. so the third test includes the glass side panel and so on)
CPU Temp after 20 minutes of the stress test - 70c
Second test I just added the glass side panel
CPU Temp after 20 minutes of the stress test - 71c
Third test I added both top dust covers
Fourth test I added the front panel
CPU Temp after 20 minutes of the stress test - 73c
Fifth test I turned off the front fans
CPU Temp after 20 minutes of the stress test - 77c
Sixth test I turned the front fans back on but switched the rear fan from 1200rpm to 900rpm
CPU Temp after 20 minutes of the stress test - 76c
and then I stopped. I didn't test the GPU but it never breaks 75c while gaming.
Kursah
Super Moderator
14,764 (2.18/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
I've done some testing with my 600C case and its fan speed controller, but never really documented how it affected my previous 4790K build or my current 2700X build. This is an inspiration to do just that though. :toast:
Deleted member 185158
This is a great idea!! wish I'd thought of that when I was running my Silverstone TJ07!!
Can we see a picture of the rig?!
4,934 (0.97/day)
this is an older pic but basically looks the same (slightly cleaner inside)
132264
18,584 (2.63/day)
System Name AlderLake
That CPU power connector to your psu , tight fit?
I don't have a case with psu tunnel but I was unable to route this wire behind the motherboard with my focus plus psu.
That wire is only 650mm long, it should have been longer.
4,934 (0.97/day)
Not to mention these small cases don't give you a lot of room from the top of the mobo to the top of the case but I was able to run the wire behind the mobo and plug it in.
