How to check for bottlenecks? Mainly CPU and Graphics Card?
9,019 (1.38/day)
System Name Black Panther
Processor i9 9900k
Motherboard Gigabyte Z390 AORUS PRO Wifi 1.0
Cooling NZXT Kraken X72 360mm
Memory 2 x 8GB Corsair Vengeance RGB Pro DDR4 3600Mhz
Video Card(s) Palit RTX2080 Ti Dual 11GB DDR6
Storage Samsung EVO 970 500GB SSD M.2 & 2TB Seagate Barracuda 7200rpm
Display(s) 32'' Gigabyte G32QC 2560x1440 165Hz
Case NZXT H710i Black
Audio Device(s) Razer Electra V2 & Z5500 Speakers
Power Supply Seasonic Focus GX-850 Gold 80+
Mouse Some Corsair lost the box forgot the model
Keyboard Motospeed
Which is the most reliable way to determine which part of your system is bottlenecking your rig?
I do have my suspicions that my E4300, even overclocked at 3.0Ghz, might be bottlenecking my 8800GT, but I'm not sure if I'm right because it's just my impression.
For example, when playing Oblivion I get +50 fps even in full view of grass and shimmering gates. However I downloaded a mod which increases the amount of NPC's (non-playable characters) and I notice that when there is a large amount of NPC's my fps start jumping from 50 to 25 and back up, causing stutter.
Also, during Crysis on high settings DX9 I mostly get 40+ fps which I think is very good for that game. But if I happen to be in an area with a lot of Koreans the fps drops down to below 10! On the other hand I get an almost constant 35-45 fps even if I'm making large explosions (graphically taxing?) but there are only 2 or 3 Koreans rather than 6+.
As regards benchmarking tools, which is what I'm looking for actually, I ran the everest benchmark which placed my processor on par with the 8400... Superpi 1M gives me 18 seconds... and I get 12782 marks in 3dMark06.
Where do you think my problem lies and how can I confirm it?
1,540 (0.24/day)
System Name :3
Processor Intel Core 2 Quad Q6600 - 3ghz
Motherboard GIGABYTE GA-EP35-DS3R LGA 775 Intel P35 ATX Dynamic Energy Saver Ultra Durable II Intel Motherboard
Cooling cm 212 EVO
Memory G.SKILL 8GB (4 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) Dual Channel Kit Desktop Memory Model
Video Card(s) BFG GTX 275
Storage WD black 500gb Samsung 1tb
Display(s) 27" 1366x768 Olevia 527v
Case Antec Three Hundred
Audio Device(s) ALC889
Power Supply CORSAIR TX Series CMPSU-750TX 750W ATX12V v2.3 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Ac
Software Windows 8 pro
hehe, anything can be a bottleneck if you hit it hard enough, you just have to deside if these things are something you wanna do and are willing to spend enough money to make it happen
btw if programs are quad core friendly you could get a really huge boost that way
2,817 (0.43/day)
louisiana
Processor Intel Core i5-12400F - Core i5 12th Gen Alder Lake 6-Core 2.5 GHz LGA 1700 65W
Motherboard GIGABYTE B760M--DS3H LGA 1700 DDR4
Cooling CPU - Thermalright Assassin King 120 SE / Case - cooler master 120mm rear case fan (Air cooling)
Memory CORSAIR Vengeance LPX 32GB (2 x 16GB) 288-Pin PC RAM DDR4 3200 (PC4 25600)
Video Card(s) GTX1060 6GB
Storage Samsung 1 TB 870 EVO SSD Main Drive / Samsung 500 GB 870 EVO SSD Backup Drive
Display(s) ASUS 23" LED Monitor
Case COOLER MASTER Centurion 5 (silver & black)
Power Supply CORSAIR RM-750X 750W Modular ATX
Software Windows 11 Pro 64bit Edition
well the enemy are AI generated charactors so thats why they use a lot more resources than explosions which are mostly much less taxing depending on the situation.
i cant help you with the rest
5,147 (0.73/day)
AZ
System Name Thought I'd be done with this by now
Processor i7 11700k 8/16
Motherboard MSI Z590 Pro Wifi
Cooling Be Quiet Dark Rock Pro 4, 9x aigo AR12
Memory 32GB GSkill TridentZ Neo DDR4-4000 CL18-22-22-42
Video Card(s) MSI Ventus 2x Geforce RTX 3070
Storage 1TB MX300 M.2 OS + Games, + cloud mostly
Display(s) Samsung 40" 4k (TV)
Case Lian Li PC-011 Dynamic EVO Black
Audio Device(s) onboard HD -> Yamaha 5.1
Power Supply EVGA 850 GQ
Mouse Logitech wireless
Keyboard same
VR HMD nah
Benchmark Scores no one cares anymore lols
shoot my quadt at 4GHZ will still bottlneck an 8800gt, cpu's seem to be the major weakpoint in most rigs. but if it isn't affecting normal gameplay, I wouldn't worry about it. no use in going out and buying a more expendsive cpu only to find out that you're still bottlenecked. lol
bottlenecking is part of the rig no matter what you do. if it's not the cpu, it's the gpu, if it's not the gpu, it's the monitor, if it's not the monitor it's the memory, if it's not the memory, it's the hd, if it's not the hd , it's the motherboard. and so on and so forth. therse really no such thing as an unbottlenecked rig these days.
the situations you're describing are typical for the titles, oblivion is glitchy especially with a mod installed and crysis is the worst optimised game in history. (well maybe tied with vampires the masquerade: bloodlines)
now if you were getting these problems in cod4, hl2 ep2 or some other well optimised title, then you might have a reason to upgrade. but if you were to upgrade, I'd do your memory as well, some nice 1066 ddr2 would greatly help with ocing.
9,019 (1.38/day)
Processor i9 9900k
Keyboard Motospeed
7,238 (1.06/day)
Memory 2GB DDR // 8GB FB-DIMM
Audio Device(s) Audigy 2
Problem about "bottleneck" is that it is different for every application. So what bottlenecks a benchmark, is different from what bottlenecks ONE game from ANOTHER, etc.
3Dmark06 is a nice overall power test. BUT, Quad cores score much higher CPU marks than Duos. While it is true that they can process twice the threads of a duo, in practice, most games are not optimised for quad cores. Hence a 3dmark06 score isnt such a great demo of typical games performance.
Try running 3 other benchmarks (they dont take long).
1./ Lightsmark
2./ FurMark
3./ AquaMark
None of these 3 are all-rounders like 3dmark06. BUT they do scale more realistically with typical game performance. Here are a few comparisons:
http://forums.techpowerup.com/showthread.php?p=779470#post779470
http://forums.techpowerup.com/showthread.php?p=742045#post742045
Dont worry about these being AGP benchmarks. The point is to compare CPU and GPU speeds on benchmarks other than 3dmark
spearman914
3,338 (0.54/day)
Brooklyn, New York 11223
System Name Mine | Dad + Mom
Processor E8500 E0 Wolfdale @ 4.6GHz 1.5V | E2180 M0 Allendale @ 3.0GHz 1.3V
Motherboard Asus Maximus Formula (X48) w/ Rampage BIOS | Asus P5Q Pro (P45)
Cooling Xigmatek Rifle HDT-S1283 w/ SFF21F Fan | Arctic Cooling Freezer 7 Pro
Memory G.Skill Pi Black 2x2GB 1.02GHz CL5 | OCZ Reaper 2x2GB 1.05GHz CL5
Video Card(s) Sapphire 4870X2 2GB 820/1020MHz | Sapphire 4850 1GB 700/1100MHz
Storage WD VR 150GB 10K RPM + WD 500GB 7.2K RPM | WD 200GB 7.2K RPM
Display(s) Acer P243WAID 24" 1920x1200 LCD | Acer V193W 19" 1440x900 LCD
Case Cooler Master HAF 932 Full-Tower | Antec Twelve Hundred Mid-Tower
Audio Device(s) Fatal1ty Xtreme Gamer w/ Z-5500 5.1 | On-Board Audio w/ S-220 2.1
Power Supply PC Power and Cooling 750W Non-Modular | Corsair HX-520W Modular
Software Windows Vista Home Premium X64 | Windows Vista Home Premium X64
Benchmark Scores Not Wasting Time!
A benchie should give you an answer. Compare your results with someone with the same hardware. If one score is lower then expected then that means its bottlenecked.
smig
156 (0.03/day)
Israel
System Name Smig
Processor AMD Athlon 64 X2 5600+
Motherboard MSI K9n6SGM-V
Cooling Arctic Cooling Alpine 64 + 2 80 case fans
Memory 2gb DDR2-800 5-5-5-15@400MHz
Video Card(s) Inoision 9600GSO 384mb
Storage 2x Seagate SATA2 250gb - RAID-1
Display(s) no name 19" LCD
Audio Device(s) On-board 7.1
Power Supply Topower 500w
Software XP Pro SP2
as said before, and as you said yourself, even the same game will behave differently in different situations.
if you mostly play single player games that mostly require AI then you need a better CPU and memory to support it.
for multiplayer games you can use a less strong CPU but you will need a better internet connection :D
JC316
Knows what makes you tick
9,397 (1.34/day)
System Name Budget Gaming
Processor AMD FX6300
Motherboard Gigabyte 880GMA-USB3
Cooling Coolermaster Hyper 212+
Memory 8GB Ripjaws DDR3 1600
Video Card(s) HD7850 1GB
Storage 1TB Sata2
Display(s) Acer 24" LED
Case Generic black
Audio Device(s) Stock onboard
Power Supply FSP Aurum Gold 650W
Software Windows 7 Home Premium 64bit
Lets put it this way, with a Q6600@ 3.6GHZ, I was making 13K 06 scores. You don't seem that bad and if your games run smooth, then you don't have a bottleneck.
CDdude55
Crazy 4 TPU!!!
8,178 (1.26/day)
Virginia
System Name CDdude's Rig!
Processor AMD Athlon II X4 620
Motherboard Gigabyte GA-990FXA-UD3
Cooling Corsair H70
Memory 8GB Corsair Vengence @1600mhz
Video Card(s) XFX HD 6970 2GB
Storage OCZ Agility 3 60GB SSD/WD Velociraptor 300GB
Display(s) ASUS VH232H 23" 1920x1080
Case Cooler Master CM690 (w/ side window)
Audio Device(s) Onboard (It sounds fine)
Power Supply Corsair 850TX
Software Windows 7 Home Premium 64bit SP1
I don't care about bottlenecks. I just want my games to run smooth enough to play them.
7,704 (1.15/day)
System Name Back to Blue
Processor i9 14900k
Motherboard Asrock Z790 Nova
Cooling Corsair H150i Elite
Memory 64GB Corsair Dominator DDR5-6400 @ 6600
Video Card(s) EVGA RTX 3090 Ultra FTW3
Storage 4TB WD 850x NVME, 4TB WD Black, 10TB Seagate Barracuda Pro
Display(s) 1x Samsung Odyssey G7 Neo and 1x Dell u2518d
Case Lian Li o11 DXL w/custom vented front panel
Audio Device(s) Focusrite Saffire PRO 14 -> DBX DriveRack PA+ -> Mackie MR8 and MR10 / Senn PX38X -> SB AE-5 Plus
Power Supply Corsair RM1000i
Mouse Logitech G502x
Keyboard Corsair K95 Platinum
Software Windows 11 x64 Pro
Benchmark Scores 31k multicore Cinebench - CPU limited 125w
Crysis uses tons of cpu and gpu, your probably bottlenecked at both honestly, in different places.
