How to connect mobile phone to projector via USB-C?
468 (0.10/day)
Lithuania
Processor Intel Core i5 4670K @ 4.8 GHz
Motherboard AsRock Z87 Extreme 4
Cooling Lepa NeoIllusion RGB CPU cooler
Memory 2*4GB Patriot G2 Series RAM
Video Card(s) MSI Radeon R9 380 4GB
Storage Transcend SSD 740 256GB + WD Caviar Blue 1TB
Display(s) Samsung SA 300 24" Full HD
Case NZXT Phantom 530 + Bitfenix Recon fan controller
Audio Device(s) Creative SB0770 X-Fi Xtreme Gamer
Power Supply PC Power and Cooling Silencer MkIII 750W 80+ Gold
Keyboard Steelseries Apex RAW
Benchmark Scores IT WORKS
I have bought Philips GoPix 1 pocket projector. If I connect to computer via HDMI that works fine. If I connect it to my Honor Magic 4 Lite or Huawei Nova 9 SE phones via USB-C to USB-C, the projector says "No imput source".
In the "Use USB To" menu is no option to project view and if I choose any other option, it always back to "Reverse Charge".
I think I am missing something in the phone options. Could you help me to properly setup phone to project view?
You can only connect a phone that supports USB-C alt mode for display output. Basically out of all modern phones it's only the ones from Samsung that support Dex, and maybe few niche "gaming" phones.
Xiaomi's desktop mode never came to be. Huawei had something in the works, but I haven't yet had a chance to try it with my own hands.
Google promised native "desktop mode", but so far it's only available if you root a Pixel 8.
According to specs of your projector it might have support for MHL alt mode, which means you can also try an older phone with MHL. Though it may not work over Type-C cable and require an additional micro-USB to HDMI cable/dongle (as far as I remember there were quite a few phones and tablets with MHL back in a day, including my 'ole shitty Chinese THL phone).
But your best bet is Dex. Even something as old as Galaxy S9 should do.
yep Samsung DEX is the way to go my S10 does it very nicely too... even wirelessly!!
