How to disable AMD Powerplay? Help appreciated.
1,571 (0.30/day)
Kolkata, India
System Name Coffee | Maximus
Processor Intel Core i7 9700K @ 5.2 GHz with AVX/4.8 GHz cache | i7 9700KF @ 5.0 GHz/4.7 GHz cache
Motherboard ASUS Maximus X Formula | ASUS Maximus VIII Ranger (modded BIOS for Coffee Lake)+TPM2.0 module
Cooling Cooler Master ML240 Illusion | Cooler Master ML120L RGB
Memory 2*16 GB (32 GB) Kingston Fury Beast @3600 MHz CL17 | 4*8 GB (32 GB) HyperX Fury @3200 MHz CL14
Video Card(s) Zotac RTX 3070 8 GB Twin Edge OC | Galax RTX 2060 Super 8 GB
Storage Samsung PM981a 1TB+Crucial P5 1TB+480GB SATA SSD+2 TB HDD | Crucial P1 500GB+2.5TB HDDs
Display(s) LG OLED 55 G3, 4K 120 Hz, VRR, ALLM, GSync, FreeSync | Samsung 43AU9070 4K TV, VRR, ALLM
Case Corsair Crystal 460X RGB | Lianli Lancool 215
Audio Device(s) Creative Sound Blaster Z SE w LG SC9S Dolby/DTS | Realtek ALC1150 (Supreme FX) w 2.1 speakers
Power Supply ASUS ROG Strix 750G (80+ Gold) | Cooler Master MWE 650 V2 (80+ Bronze)
Mouse Cooler Master MM731 19000 DPI gaming mouse
Keyboard Cooler Master CK721 65% mechanical gaming keyboard (tactile)
Software Windows 11 Pro x64 |Windows 11 Pro x64
Benchmark Scores Cinebench R20 MT 4200,ST 547 CPU-Z MT 4871, ST 620 | R20 MT - 4158, ST - 534, CPU-Z MT 4798, ST 603
I am facing some silly lag issues while doing some tasks like say presentations on prezy or Windows Aero in 1080p. I want to modify the AMD PowerPlay profile but I am not able to do it. I looked at other threads but the solution there is either for ULPS or for older Catalyst versions. I do not want to disable ULPS. I just want to modify the idle clocks. Is there any way? Thanks.
6,881 (1.42/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
disable ULPS in afterburner, is one way to do this
making a low clock profile helps too if familiar with afterburner.
1,571 (0.30/day)
Kolkata, India
http://i.imgur.com/1c6sCS3.jpg
Yeah but disabling ULPS will cause higher power consumption. The thing I want to do is that I want to keep power play functional but I just want the idle clocks to be higher. Any ways to do that?
6,881 (1.42/day)
Florida
Storage Various
yeah
create 2 profiles in afterburner.
save default to profile 1 & 2
edit profile 1 move core up 100 mhz from idle set as 2D profile in settings.
43,629 (6.36/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Shaolinfist
22 (0.01/day)
South West England
System Name Dell XPS 420 Overcharged
Processor Q6600 OC@3050Mhz
Motherboard Dell BTX
Cooling Stock
Memory 6GB Crucial
Video Card(s) XFX HD5770 OC@960/1410
Storage 1TB
Case Dell XPS 420
Power Supply FSP Blue Storm Pro 500w
Software Windows 7
Also if you use Afterburner goto the settings > profile tab and it has the option to set 2d/3d clocks. I have heard some people use this successfully however I wasn't able to get it to work with my card. If that is the case the guide posted by erocker is the same one I used to set my default clocks and although I have to manually enable it with each boot it works just fine.
11,880 (2.15/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
1,571 (0.30/day)
Kolkata, India
43,629 (6.36/day)
