- Nov 13, 2007
- 11,377 (1.76/day)
- Austin Texas
System Name | Arrow in the Knee |
Processor | 265KF -50mv, 32 NGU 34 D2D 40 ring |
Motherboard | ASUS PRIME Z890-M |
Cooling | Thermalright Phantom Spirit EVO (Intake) |
Memory | 64GB DDR5 7200 CL34-44-44-44-88 TREFI 65535 |
Video Card(s) | RTX 4090 FE |
Storage | 2TB WD SN850, 4TB WD SN850X |
Display(s) | Alienware 32" 4k 240hz OLED |
Case | Jonsbo Z20 |
Audio Device(s) | Yes |
Power Supply | Corsair SF750 |
Mouse | DeathadderV2 X Hyperspeed |
Keyboard | Aula F75 cream switches |
Software | Windows 11 |
Benchmark Scores | They're pretty good, nothing crazy. |
Wire brush will be effective - you mentioned that the paint is chipped and scratched - that pretty much proves that the wire bursh won't have too much of a hard time with it.
IMO the paint removal "effort" rating (ranked from easiest to hardest):
1. Getting it done for you.
2. chemical reaction
3. sand / media blasting
4. wire brush
209. Sanding by hand
In terms of cost:
1. Wire Brush - $3
2. chemical reaction - $5-$10
3. Sanding by hand ~ $10
4. Media/Sand Blasting ~$60
4. Getting it done for you ~$depends on who you know.
you can get grafitti remover online, i have no clue where to go and buy it...
4. wire brush
In terms of cost:
1. Wire Brush - $3
