How to FSB in CrystalCPUID?
desertmonk
15 (0.00/day)
System Name Absolutely Useless...
Processor Athlon X2 5000+ (Brisbane) (@3.0ghz. 13x231 1.35v 1155mhz~ HT)
Motherboard Dell (propriety from asus) M2N nForce 430i
Cooling Stock (Delta Electronics "S940 type II" I believe)
Memory 3GB PC5300 @770mhz single channel (mixture of Nanya and unknown DIMMs)
Video Card(s) Force 3D Radeon HD4830 w/ Artic Cooling HSF
Storage WD Caviar Blue 250GB 7200rpm 16mb cache
Display(s) Dell SE1908WFP
Case Dell Inspiron 531
Audio Device(s) Onboard (Realtek AC97)
Power Supply Coolermaster Extreme 650w
Software Vista Home Premium 32bit
Benchmark Scores 3D mark: 8500 @ stock. 9600 overclocked Freestone Group GFX bench: 300~ (hates ATI chips)
Basically... HOW THE BLEEP DOES THIS THING WORK LOL :O
I can change Vcore and multi by going to "function > K7/K8 multiplier." I am guessing you can't actually fiddle with FSB on this program?
I have an OEM BIOS and an OEM MOBO, so am very very limited with options, Vcore being a rather key one of them so I am practically delighted that I appear to be able to change vcore using CrystalCPUID (i can't in nTune, for example)
In nTune i can change FSB, HT multi, some (all but tRCO unfortunately) ram timings
In CrystalCPUID i can only change Vcore and CPU multi (down, for some reason Dell didn't offer me a black edition... can't think why...)
I guess there are two questions there:
1) Is the voltage actually being changed? CrystalCPUID reports it as changing, so to does CPU-Z (I don't really believe the voltage is changing, because the BIOS is totally locked, and never been able to change it through any other software)
2) Can you change FSB/HT multi on CrystalCPUID
The reason i don't use that is because i have no idea/haven't looked for the ICS number thingy (you know what i mean) on my MOBO.
It also looks very limited (i.e. you can only change the FSB, no vcore, multi, etc)
I also see no support for any nForce chipsets...
Thanks for the reply though! And I've just re-read my title... "how to FSB" lol, worded that a bit wrong don't ya think :/
Yes, if you can confirm CPUz is showing a change, then yes it has changed.
Unfortunately, you cannot. You need to use another tool, like aforementioned nTune or SetFSB.
:D
ok, well thanks for all the replies. I guess it's back to extremem config editing for COD games, and back to waiting till it all spontaniously blows up and i have a good excuse to step to the better teams... blue & red
You could use Clockgen for overclocking, just google it if you are interested.
