- Jul 25, 2006
- 14,311 (2.06/day)
- Nebraska, USA
System Name | Brightworks Systems BWS-6 E-IV |
Processor | Intel Core i5-6600 @ 3.9GHz |
Motherboard | Gigabyte GA-Z170-HD3 Rev 1.0 |
Cooling | Quality Fractal Design Define R4 case, 2 x FD 140mm fans, CM Hyper 212 EVO HSF |
Memory | 32GB (4 x 8GB) DDR4 3000 Corsair Vengeance |
Video Card(s) | EVGA GEForce GTX 1050Ti 4Gb GDDR5 |
Storage | Samsung 850 Pro 256GB SSD, Samsung 860 Evo 500GB SSD |
Display(s) | Samsung S24E650BW LED x 2 |
Case | Fractal Design Define R4 |
Power Supply | EVGA Supernova 550W G2 Gold |
Mouse | Logitech M190 |
Keyboard | Microsoft Wireless Comfort 5050 |
Software | W10 Pro 64-bit |
Those would indeed be very cheap UPS and as you said, not recommended for computers.Most of the cheap "power strip" style UPSes are straight square wave, even the APC ones.
That said, even the cheapest UPS I could find from APC, the tiny 350VA/200W BE350G for $49.99, has stepped approximation waveform output.
I sure doubt and would not trust the accuracy of what HWMonitor is showing! It is relying on motherboard and graphics card sensors which are notoriously cheap (inexpensive) and inaccurate, very low-tech devices.Like I said, I don't doubt it's accuracy, it just doesn't show actual load unless it's running off the battery.
For example, look at the voltages shown by your OCCT screenshot. If your +12VDC was really at +6.09VDC as shown, your computer would not be running. Your +5 and +3.3V readings are below acceptable ±5% tolerance levels too.
These readings are not uncommon with software based monitors. Speccy, for example, shows the voltages in my system to be the following:
+3.3V = 2.028 V
+5V = 3.367 V
+12V = 0.048 V
+3V CMOS battery = 1.524V.
So for sure, you need to totally ignore those values and don't worry (or even think) about it and just go by what PowerChute says if you are interested in your loads.
