how to prevent external hdd to turn on by booting up the system
Hrhrhr
13 (0.00/day)
Hi
i have two WD external HDD connecting to my desktop computers
in one pc when i turn on the system HDD will stay off and when ever i need i turn it on manually. however in the other pc HDD turn on as soon as i press the power button.
how do i prevent this from happening?
in both systems the MB is from asus
the one that stays off is H81-Plus
and the one that turn on is H97-Pro
thank you
dorsetknob
9,106 (1.24/day)
Explanation may be as Simple as
External Hard Drive (3,1/2"Desk top Drive will require separate power Supply to power on )
External Hard Drive ( 2,1/2" laptop Drive fitted into enclosure powered by USB comes on with M/B Booting ) how to stop this UNPLUG IT FROM USB
12,340 (2.21/day)
Oregon
Keyboard EVGA / Logitech K400
Hrhrhr
13 (0.00/day)
they are both 3,1/2 (My Book Essential) with power button behind them, one stay off and one don't. unplugging is just erasing the question
6,270 (0.89/day)
New York
Processor INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts
Motherboard ASUS PRIME Z390-P ATX
Cooling CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull
Memory CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz
Video Card(s) EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING
Storage ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND,
Display(s) 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved
Case BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE,
Power Supply 1600 Watt
Maybe this...found in Bios/advanced. USB config
Now having stated the above if that does NOT work you will HAVE to use the POWER BUTTON on the My Book Essential. Good luck and welcome to TPU!
PS This is on page 92 of your users manual. Under the Title: 3.6.8 APM Configuration.
