How to quickly & easily fix coil-whine(coil choke noise)
I bet you've never heard about these brands
I've heard about Samson brand. Never used it personally but a discussion elsewhere showed that it is a good offering.
One shop owner told me he doesn't stock non-gel glue anymore
What? I wonder why. Seems a bit foolish to me. Never use the gel types. They just don't work well because they have no wicking action.
Does anyone know if someone made similar test like this?
I'm back with the results. TLDR: After two rounds of gluing (separated by 24 hours), there is only a small improvement of the coil whine at best.
In the past few days I read this whole thread to collect some knowledge and then proceeded with the operation.
I did the first round with the Samson brand, then I switched to the second one. Both had a very good wicking action. My first round was a very clean application, I made a dry run with the supplied nozzle and realized I wouldn't be able to reach all edges so I tweaked the nozzle a bit by using a transparent tape:
This was a perfect solution, it had a half of diameter of the original one and was flexible. With this I was able to push the glue directly to the edges of inductors, without any mess around. The glue was wicking perfectly until it reached the state where the inductors were "floating" and I was sure the glue is spread underneath and around.
To avoid whitening of the surrounding areas I setup a fan and let it cure for a day. However I noticed the curing wasn't that fast, it was still runny even after a few hours. Eventually the glue hardened, but you could barely see there was any glue applied, the reduction of the volume was so significant it basically all but disappeared. At best, there were some glue stripes on one of the inductors where I was unintentionally more generous with application, like the last picture in this post: https://www.techpowerup.com/forums/...il-whine-coil-choke-noise.294015/post-4964000
I think maybe the air humidity wasn't high enough (around 30% at 23°C) and it caused this volume loss.
Then I tested the coil whine, couldn't hear any difference and decided to go for another application.
This time I applied more, I let it cure without the fan (which of course caused white "snow") and sprayed a little bit of water on the motherboard (critical areas covered) to speed up curing. I also tested the coil whine again before it was fully cured (again no significant improvement could be heard) as this was suggested here to potentially improve glue wicking action.
This is the final state:
I don't believe any subsequent application would improve things (post-5051054). If there were any air gaps I think they are filled now, unless there are pockets inside the inductors. I think the best substance for using would be something like a super glue, thin, but with no volume loss during curing.
Since I read the whole thread I think I'm the fourth (or so) person with a laptop and all were unsuccessful with this method. That's something to consider too. Maybe it works better on larger inductors as found on graphics cards. Since my laptop is older and outside of the warranty, there is no harm done, but I would think twice to do it on a brand new device - maybe only if there were no other alternatives.
I will report back if there will be any change to the coil whine in the coming days. In theory the glue can be in a liquid form in some areas. It happened to me several times where the nozzle of the super glue is blocked, but the rest in the packaging is still liquid. This could be the same - the outer shell is cured, but the glue in the coils can be partially liquid.
I've seen that happen. Give it a few days and see how it goes.
Hi I have a hellhound 7900xt with pretty extreme coil whine, I've tried undervolting and running the card for longer periods of time in gpu intensive stuff but I think I'll just have to stuff the card with thermal pads and superglue the inductors.
Would these products be suitable? the first two come with applicator tips which will probs make it easier to work with and in different viscosity options
In my opinion, lower viscosity is the best so it can "wick" under the component. I would peruse this thread, it has some very good suggestions and advice specifically by @lexluthermiester
View attachment 398779View attachment 398781View attachment 398780
I looked those up and they seem to be the thicker type, which is not optimal. As mentioned above, you need a type with low viscosity for good wicking properties. As for your highlights, Looks like you have all the right part selected. Some make sure you get the lower viscosity type and you're good.
Sweet, i'll have a look around around, though I think either the thin or medium thin for this brand would work
Sagging under the weight of the gigantic coolers can cause the PCB to deform and results in coil whine.
Make sure you use holders / brackets to support your cards to be perfectly horisontal.
Just my 5 cents. When the GPU is sagging your least worries is a possible coil whine but, ripped pads under VRAM and GPU core which is fatal for any GPU.
If I don't want to superglue, can I use TG Shield? Do thermal pads dampen coil whine? Or why are there more reports on Astral/TUF which have no pads compared to Prime which has pads?
