How to read .m2ts and .ssif files on HTPC?
1,221 (0.23/day)
Canada
System Name Brutus
Processor i5 4690k @4.7Ghz (Watercooled)
Motherboard z97 MSI Gaming 5
Cooling NZXT Kraken x61 AIO watercooler
Memory Gskill Ripjaws 8gb (2x4gb) 1600mhz 7-8-7-24
Video Card(s) MSI Gaming GTX 980ti x2 (sli)
Storage 1 SSD 64GB (OS) + 2x500GB WesternDigital RAID 0
Display(s) YAMAKASI Catleap q270 SE 27inch Glossy 2560x1440
Case NZXT Phantom
Audio Device(s) ASUS Xonar DX
Power Supply Antec TPQ 1200w
Software Windows 7 (64 bit)
Hi I've started the process of ripping my entire blu ray collection to my HTPC so I can stream my movies to my laptops, tablets and cell phones in the house.
I've installed and configured Kodi. But I do not know how to read those files on Kodi. Is there a way to "mount" those files or read them? some of my movies are 3d movies (.ssif)
Kodi menu under video / add video / then point to the directory.
If you set the name up like Name.year It will scan indb for the info in the movie
Then you will have new menu item called movies
Kodi has its own codex. Then you have to change the sound options under preferences depending on your sound set up.
There's a learning cure with Kodi but ounce you get it you will be hooked. I've been using it for over 8 years
yes I've already got my libraries set up and directories. Kodi does find my 3d movie. And it does start the movie, but in 2d only not in 3d. I don't have the 3d icon (to switch 3d on) at the bottom right.
It probably read s the m2ts file as a 2d file when it actually has the 3d content in it.
Kodi associates the m2ts file with the .ssif file. the .ssif is the huge 39gb file whilst the m2ts barely has any size at all.
Last time I checked Kodi does not support 3D. But check the forums they may have a add on for it
